...it had started stalling on me. Of course it did not happen on the test ride! It seems to be happening once the bike is fully warmed up and only when there is no throttle at all. It restarts immediatley when you press the starter - but it is a little worrisome when it happens at a noisy intersection and you have not heard that the engine has died....
The usual suspects:
1. Dreaded Evap System? (but it seems to restart without any problem unlike the evap/vacuum problem)
2. Loose Spark plug wire (doubtful since it restarts so quickly)
3. Idle adjustment too low (? maybe since even the slightest throttle will prevent it from stalling)
4. Bad/old gas?
I am really nervous that I bought a lemon or something. I have called the previous owner and he is not getting back to me - of course.... great what did I just buy? Help me feel better about this purchace.
I posted over at af1racing too - but since this is the same drivetrain as the GTS, I assume the lessons learned from the other 250ie owners may apply here.
I am searching the wiki as we speak - but have not found an idential issue/symptom yet.
Thanks for any help.
⚠️ Last edited by Baldanzi on UTC; edited 1 time
