@big_foot avatar
Scooterless at the moment
@big_foot avatar
Here's some pic's of the air horn on my P200E,
It's not as loud as I had hoped, I may have to put in a better air hose.
I had to tape up the air horn where it was shaved down to fit the horncast,
Water was getting into the horn and made it sound weaker.
Although it might also be because of the hose being not firm enough.
@rover_eric avatar
@rover_eric avatar
How much louder is it than the stock p200 horn?
@big_foot avatar
@big_foot avatar
It's definitely got a louder sound,
One quick push of the horn button only activates one of the dual horns,
But a long press of the button activates both of the air horns.
It's loud enough for me.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Probably sounds less like a dying goose too?
@danyouhandleit avatar
1967 Gran Turismo 1963 Lambretta S3 TV175 1971 Rally 180
Weird.
@rover_eric avatar
@rover_eric avatar
i guess the question is :
Do you think the safety gained from the increased loudness of the horn ( providing it's substantially louder ) is worth the cost of the horn plus the time to install plus the cutting holes in your frame, and loss of glovebox space?
Is it worth it?
@big_foot avatar
@big_foot avatar
Is it worth it?
Definitely worth it.
I haven't had a problem with cell phone toting SUV's since installing it,
Also It's been great to stop sudden lane changers when I'm up to speed.
The dealer btw installed this horn for free,
Mainly because this is something new to them.
They have never installed an air horn on a P200E before.
@big_foot avatar
@big_foot avatar
Here it is with the horncast placed back on again,
The badge fell off, So I've used double sided tape on it until I can glue it on better.
All the stores are closed today...It's Canada Day.
@koenig_blues avatar
thats creative Razz emoticon and yes in some place with lots of traffic or big loud truck walking around a normal horn wont work well.. it happen to a friend of mine while he riding his vespa and a truck pit him so close and almost hit him in the side of his bike and he is luckly he have a loud horn to tell the truck driver that there a little vespa in the side of the truck and almost get crush..
i believe some folk did took their vespa in a loud crowded road so safety does count inluding for a horn that can tell other ppl in the road about ur present if some ppl drive to close to u (after all thats what a horn use for)
accept if u only ride it near ur home and never hit the free way or even just use ur vespa in weekend guess u dont need loud horn at all Razz emoticon
@phaetn avatar
'78 Super 150 Mk II ported DR177, banded clutch, ASC Big Bore
@phaetn avatar
Double check the installation (if you still have the manual). I have a Stebel Magnum compact, too (that I installed myself) and it's oriented 180° on the vertical plane to yours, so that the two leads are facing down.
This may or may not affect your horn's perfomance (certainly it has to be within about 15° of the vertical and if it's not the compressor won't work well). I'm not sure about it being totally upside down.
Secondly, make sure that they installed the horn with the relay that was provided. Some people choose to forgo it (as it takes extra wiring and some space), but this can lead to a dead horn -- sometimes within just a couple of months -- as it gets too much juice.
Here's a pic of my installation (in the cowl glovebox, with the 18 amp/hour sealed lead acid battery underneath it).
There's extra wiring there for the twin Hella lights I have installed on the front rack:
The Stebel air horn is definitely MUCH louder and effective than the strangled duck stock horn. It can take a quick second to spool up (the compressor) but it's definitely loud! Stebel also makes a non-compressor version that's also very loud and probably has a quicker response time.
To activate it I just set up a cheap doorbell by my left foot. I didn't want it anywhere else, or to mess with the original wiring of the scooter (a non battery 6V setup). I had tried other switches, but they were hit and miss. The doorbell can be easily replaced for under $5 if it stops working.
@monza avatar
63 VNB
@monza avatar
63 VNB
Check the voltage at the air pump while its running. If its less than 12v, then that could be the cause of the lower sound output. If this is the case, you will need to run a heavier gauge wire to the battery and use a relay to switch it on and off (connecting the coil of the relay to the original horn wiring). The original wiring in the scoot is just barely adequate for the standard horn, let alone an air compressor...
@big_foot avatar
@big_foot avatar
I'm hoping that there is a relay installed,
I forgot to ask them when they installed the air horn.
I'm taking it in friday evening to get a Euro style petcock installed,
The plastic lever type standard petcock is faulty and not working properly.
I'll ask about the relay when I go in on friday.
@big_foot avatar
@big_foot avatar
Found this quick tutorial on air horns and installation:
http://www.gadgetjq.com/airhorn.htm
nothing at all
nothing at all
i have to add my two cents here.
i love the things but to say its better than a good stock(battery P) horn is missleading.
it IS different.
the stock is a loud small source and the air is a loud large source.
i tend to think people are more likely to think BIG when they here the air horn.(imho)
with that said,i really think horns are rude and should be used in emergency situations.(unless it sounds like a duck,then it's cool)
i run a wolo air horn on my P and stock duck on the et3.
@yanuarputra avatar
New PX 150 2006, Super 150 1976, Honda Vario 2006
@yanuarputra avatar
I install 2 Denso Horn
Almost 2 years old without problem, Very Loud, cause front mudguard act as a sound chamber
⚠️ Last edited by yanuarputra on UTC; edited 1 time
[quote="yanuarputra"]I install 2 Denso Horn
thats was nice and u succed to hide the howrn very well Razz emoticon .. nice job
@yanuarputra avatar
@yanuarputra avatar
[quote="koenig blues"]
Looks like standard...
But when you push the horn button, everybody will shocks!
What a loud sound....
Never get problem with battery, I add 1 relay to control the horns.
Whew emoticon I'm reading all of this thinking, "Serioulsy??? I've used my horn legitimately ONCE in the last six months."
@rover_eric avatar
@rover_eric avatar
Be careful with mounting those horns inside the fender there.
You want to make sure that the tire can't swing up that far on it's travel if you hit a huge bump, or you may actually lock the tire up, shred the rubber on a horn, or rip the horns out of the inside of your fender.
you've probably thought of this, though.
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
I like the duck fart horn. It makes me smile.
@rover_eric avatar
@rover_eric avatar
I like, at vintage rallies, when everyone's lined up for a ride and you can get a chorus of duck horns going.
@peterc avatar
2009 Vespa GTS 250, TBA
@peterc avatar
I mounted my Stebel Nautilus on the left side of my rear rack. A horn that loud doesn't really need to be mounted up front, and I don't mind the noise because (a) I always wear a helmet, and (b) I already have a good deal of hearing loss from gunfire in the service. I also have the horn button mounted where I can reach it with my left foot. All I can say is, the Stebel is a very effective accident avoidance device in this retirement community where most drivers are deafer than I and apparently blind as well!
nothing at all
nothing at all
i'm not sure if your making fun of the statement or not.
i use my et3 horn alot because it sounds funny,really funny with other ducky boys and girls.
THE air and LOUD stock horn never unless absolutly neccesary.
it is just bad form to go blasting a horn willi nilli Nerd emoticon
(that goes for any car or bike)
@gatekeep avatar
1974 Rally USA 200 1980 P200e
@gatekeep avatar
I'm going to hold out for a better solution... Theres got to be a simpler way? Nerd emoticon
@yanuarputra avatar
@yanuarputra avatar
Thanks,
Allready tested. full travel of front tire did not hit the horn, Tested with "hard breaking" with full of load at backrack and (only for testing) full load of front rack, the tire still did not hit the horn.
So, after all, I can tell this is safe, as long as you mount the horn with good position, trial 'n error the best place, and make sure tire not hit the horn on full swing position.
Will report if i get another result, but in the last 2 years, daily riding with different type of roads, everything is ok for me.
No, not making fun. I do find this thread amusing though. I guess the sound of my horn is something I've yet to consider. Maybe I will now though!
nothing at all
nothing at all
if you have a battery p,your horn should be great.
they do go old,a new stock p horn is plenty good(imho)
@big_foot avatar
@big_foot avatar
I use mine daily, Toronto has some really really dumb drivers.
Try driving in Los Angeles
@big_foot avatar
@big_foot avatar
Fortunately the Sito+ muffler helps a lot too,
They hear me coming and then change their mind before changing lanes.
8)
nothing at all
nothing at all
see,this is my point.
i do ride in la.
no problemo.
i feel the time i waist pushing the horn and the danger of flipping off and taking my mind off whats really going is greater than just avoiding and movin on with my ride. Nerd emoticon
@peterc avatar
@peterc avatar
Suum cuique (to each his own).
@brett_k avatar
2005 Vespa PX150, 1976 serveta jet 200
@brett_k avatar
I've been saved by my air horn at least 3 times since I put it in 2 months ago. People just don't see scooters/motorcycles very well.
@robbyrivai avatar
Yamaha MIO :P
@robbyrivai avatar
Yamaha MIO :P
Yes! too bad PX horn doesn't sound like that...
1997 T5 Classic
1997 T5 Classic
can you get an AC-DC convertor for a stebel? ideally id like to keep my px ac and batteryless
You've been saved three times in the last two months? How often did you almost die before you put it on?
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
You guys don't spend enough time in the "general discussion" section. There's always a thread about "how often do you use your horn" popping up. Usually leads to stupid arguments too. I like to keep in mind that different locales have different driving conditions, and different riders have different approaches. I think you can be very safe almost never using your horn. But I also think using your horn can be a good tool to making yourself "visible." I see no reason to get fired up over it. Leave that to the General Discussion, right?
nothing at all
nothing at all
wrong
the stock horn is a 'not-so-modern' item Nerd emoticon
nanananana Razz emoticon
honestly, it is a stock over mod difference.
some of us like stock and some like mod.
(i like a little of both)
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
I wasn't talking "stock vs mod horn." Some of the discussion was drifting toward "horn vs no horn"... a discussion I think is pretty loaded since different riders have different needs and styles.
Stock vs mod... that seems like a very worthwhile discussion I'm gonna replace my old toast one and see how it goes with stock. But if I feel a new stock horn wouldn't do the trick should I need to honk, I wouldn't hesitate to upgrade.
safety first everyone Razz emoticon
and i mean it
[ Time: 0.0142s ][ Queries: 3 (0.0066s) ][ live ][ 343 ][ ThingOne ]
