@kdude avatar
@kdude avatar
Is the oil filter for the 250 and 300 the same ?
I have a 300 and would like to do my first oil change. Anys suggestions on how to remove it ... do i have to buy a special oil filter tool ?
Any suggestions would be welcome...
thx,
Hp
@harvey avatar
@harvey avatar
Jettin makes a combined oil filter/drain plug wrench.
http://www.jettin.com/jettinTools.htm
While Oopsclunkthud offers these snowflake oil filter tools
http://oopsclunkthud.com/
Edit: For the first service (1000kms) let the dealer do ; they're supposed to go over the scooter & make sure it's properly adjusted.
Regards
Harvey
@kdude avatar
@kdude avatar
Hi Harvey... thanks for the heads up... you ride a 300 ? i saw a flilter with a different type of head .. dont have a pic with me now but it looked like you needed a different type of oil filter tool...
@scooter_west avatar
Sponsor
Sponsor
The ones in the oops clunk thud pics are the two types of filters out there. There are tons of different tools out there. Most shops have developed their own system. They all seem to work well. Here are two more:
@kdude avatar
@kdude avatar
I like the one in the second pic... will that work on the original filter that comes with the 300 ? If so i'll order one in the morning..
thx, Hp
@mesmer avatar
GT200
@mesmer avatar
GT200
Here's my method
edit-- And I just hand tighten it when putting on the new one.
@kdude avatar
@kdude avatar
Mesmer wrote:
Here's my method
I have that exact tool...i'm just afraid that the factory did not tighten the filter on the scoot by hand .. i normally hand tighten too...
Sponsor
Sponsor
thx, Hp
Yes, the original ones have the slotted heads....
http://www.scooterwest.com/item_detail/Oil-Filter-Socket-Tool/2373/
Some filters use this tool: http://www.scooterwest.com/item_detail/Oil-Filter-Socket-Tool/2373/
Others use the tool that was posted by another member above.
@mesmer avatar
GT200
@mesmer avatar
GT200
kdude wrote:
Mesmer wrote:
Here's my method
If you do your own oil and filter changes, you'll be glad you only tightened it by hand when trying to remove it the next time.
@theoz avatar
Sir Frets-A-Lot
Sir Frets-A-Lot
@theoz avatar
I trust the OopsClunkThud Snowflake... Most people I know do too.
Really is a well designed tool that just plain works right.
The Host with the Toast
Mesmer wrote:
Here's my method
+1
This works for me too or just twist it off with hand.
@joshzingzing avatar
or you could smash a scredriver through the guts of it and turn it that way
this can be a bit messy though
And in a pinch you can sharpen the ends and use it as a throwing star.
Wayne B
@astromags avatar
@astromags avatar
I like this type. It has a rubber strap and is pretty much infinitely adjustable. Got a set of two at Auto Zone for about eight bucks.
@tonyf avatar
Red SYM HD200
@tonyf avatar
Red SYM HD200
My only question is about leverage. If someone put the filter on too tight to begin with how would this snowflake be more effective than the other tools which all give a person more leverage when loosening a filter?
@windbreaker avatar
@windbreaker avatar
+1 on the question.
Last time I changed my oil, I had to tighten the filter to its max to stop the oil leaking from it. I'd hate to have to remove that one with a snowflake.
The jettin tool has the added benefit of dealing with the oil plug.
FTR, to remove the old, slotted filters, I insert a file to function as a screw driver, and I torque it with a pair of pliers as shown above. The file nicely bites into the slot and does not slip.
@chukstr avatar
Dragon Rosso LX 150
@chukstr avatar
Dragon Rosso LX 150
+1
That's what I've always used.
@tonyf avatar
Red SYM HD200
@tonyf avatar
Red SYM HD200
Messy, too messy 8)
@fogie avatar
@fogie avatar
Just curious:
Are there specific torque settings for the filter and/or drain plug? And if so, how important are they?
@harvey avatar
@harvey avatar
From the wiki
Oil Filter 4-6 Nm 3-4.5 ft-lbs Oil the rubber gasget
Oil Drain Plug 24-30 Nm 18-22 ft-lbs Check, clean screen
The oil drain plug is a problem if you strip it.
MV Maintenance Clinic, SF, 2007 - First Day notes
dchernikoff wrote:
MV Maintenance Clinic, SF, 2007 – First Day notes
9. Replace the o-ring and the plug (lubricating o-ring and threads with oil first). Watch while you are screwing it in, that the o-ring doesn’t get pinched. Not too tight – if you strip the threads, then you have to have it re-tapped, and there is only one tool in the country to do this (which belongs to Rolf).
-Dan
Regards
Harvey
Let's get this clear - filters are done up hand-tight (lubricated), and I've never ever had to replace an O-ring yet on a drain-plug (or seen one replaced at a dealers), which should be 'nipped' up, not 'tightened'.
Sometimes the 'worst-case' recommendations are regarded as gospel by some. Use some discretion...
@harvey avatar
@harvey avatar
My feeling is you can learn how tight is good enough by
a) Stripping some threads and breaking off a few bolt heads, or
b) Torquing them to the factory recommended values until you have the ‘feel’.
Having done the former, I would recommend the latter.
cfargo wrote:
Looks like a good tool for removing these 2 (although I have yet to get one of the newer filters with a nut on it) but beware that both of these have very low torque specs. Just 4-6Nm for the Oil filter and 24-30Nm for the drain plug. I worked on a scooter this past weekend whose drain plug was on with 75Nm+ torque, a good way to cause damage. Depending on your grip, 4-6Nm isn't much more then hand tight.
windbreaker wrote:
daysailer1 wrote:
I was told that I would not be able to perform this operation without a 24mm combo wrench. It fits the drain plug perfectly. Thank you Pete at Sportique!
Yes, that helps. I had to do my first one with an adjustable wrench--not a nice tool for that.
Now that I have a torque wrench, I checked how tight I had it on: 60 lbs ft!
The recommended torque is 20! Oh well, the thread is still on. Whew emoticon
Giuliano wrote:
Having once bought a bike with a poorly repaired cracked sump second-hand I have always used a torque wrench on the drain plug.
Tightening and/or Torquing Bolts. Best Practices?
Regards
Harvey
+1
@tonyf avatar
Red SYM HD200
@tonyf avatar
Red SYM HD200
Reminds me of the old saying, the one who make the least mistakes typically has much experience. How do you gain experience? By making mistakes.
[ Time: 0.0220s ][ Queries: 4 (0.0091s) ][ live ][ 343 ][ ThingOne ]
