Everything still works except now that I lost compression in the cylinder and it won't start. I guess now I have the perfect excuse to upgrade. I have already installed the Sito plus with 103 jets on my 2005 Vespa PX 150.
I have been on the net researching and so far I found unsatisfying, limited detailed and information on each cylinder kit that would give me the best educated choice. What I want is a high quality, bolt add on cylinder kit that will give me smooth, fun day in day out, daily forgiving and useable power and torque for mostly city, hilly riding and traffic; and to occasionally get me up to and slightly past hwy speeds to a keep up traffic of a cruising at top speed at about 60 -70 mph; along with a trouble free reliability. I do not want a hot, stressed out kit or set up that will burn out my engine and requires machining to get the most out of the kit. Also, I don't want to be stuck andforce into using expensive, high quality synthetic only, 2 stroke oil or/and high octane fuel. I always used mid-grade. Also, another reason I want a bolt on is that if I should sell my Limited Edition 05 PX 150, the next owner has an option to convert it back to stock. Is my criteria is asking too much and is my thinking being unreasonable and unrealistic?
This is how I narrowed it down. I do not want a standard basic cylinder kit for my three port that only get its performance by increasing its ccm by 20%, so the reliable DR is out. I want to increase the ccm but also with a high quality and an exceptionally reliable, proven designed and engineered kit. Polini 177 and Molossi 166 are a hot racing, high performance kit. that are designed, focus and are happiest at the higher end power band; best suitable for racing or an aggressive riding. Also from SIP Scootering, a too pricy $587 US QUATTRINI 172 M1X cylinder kit, is suppose to leave the other brands in the dust, but then I suspect that it is a hot, full race design.
Which now leaves me with Pinasco 177 aluminum Cylinder Kit? Pinasco is advertised as the ultimate Vespa 3 Port Cylinder Kit and claiming 12.5 hp, roughly the same output as the Molossi; however Pinasco claims not to be as aggressively ported as the Malossi 166cc or the Polini 177cc, but is a much higher quality product with longer lifespan; it has been discribed as an ideal, hefty touring kit with lots of torque and absolute longevity, I think they are saying that it has a wide and useable power band, not narrowly focus at the racing top end, with lower motor stress. If so, then this is exactly what I am looking for. The advertised kit consists of a Ghilardoni Aluminum jug with Nicasil lined bore and a top notch ASSO piston. I have no idea or knowledge of its rated quality, but it sound good to me.
Just from reading, you guess it, I want to purchase the Pinasco 177 cylinder kit, because of longer lifespan and seemed to be understress and cooler running, at least compared to Molossi and others. By the way, I was just on Pinasco website and they are bringing back and claiming a much improved classic cast iron 175 cylinder kit. Hmmm.
Ok, what do you think? Am I on the right track
For now the cylinder kit will be match with a stock SI 20/20 oil injection (103 jets) and a Sito plus exhaust. If I must, I am willing to upgrade the carburetor, only if nesscessary and only if it is an oil injection. By the way, what do you think of the trick out Vortex modified carburetor? It seems a sound match for the upgrade kit; or is it a waste of money. I am also looking into a T5 Carburetor.
Any clean and respectful repliy will be greatly appreciated
Thank you and best regards
OK I am done.
⚠️ Last edited by rudy812 on UTC; edited 1 time
