... when they designed the battery access for the clock on the LX?!?
It's totally nuts! I had my headset opened up today anyway to convert my front turn signals to the European setup and to install a higher color-temperature headlight lamp, so I decided to change the clock battery while I was in there. Gotta say... it would have been impossible to design a more convoluted configuration for something that should be a straightforward, user-serviceable, routine maintenance procedure.
God forbid that you would decide that you need to change the battery without having your headset open anyway. First you need to remove BOTH the front and back halves of the headset (requiring removal of the mirrors, and the windscreen if you have one), then you need to disconnect the speedometer cable and completely remove the instrument panel from the rear half of the headset, and then you have to unplug one of the main connectors to the instrument panel just to expose the battery location!
If you know where to look, you'll then find the battery at the bottom of a sort of well in the circuit board. The well is plugged by a plastic cap to waterproof it, so that must be pulled out. You then see at the bottom a tiny clear plastic plate with a screwdriver slot molded into the top. Turning this plate counterclockwise with a tiny screwdriver releases it so that it can be removed with very slender tweezers IF you are dexterous enough. Once you've fiddled with fishing that out of the bottom of the hole, you are presented with a tiny, delicate metal contact spring plate. Be REALLY careful removing this, because it is perhaps only a few thousandths of an inch thick. Then you should finally be able to see the battery (a button type), which also must be fished out of the bottom of the hole with tweezers.
Replacing all the fiddly bits in the bottom of the well is also problematic, as they tend to want to flip over as you drop them in... requiring you to fish them back out. I'm a musical instrument builder by trade, and am fairly dexterous. Those of you who are at all ham-handed should not undertake this task.
Being a retired electrical engineer, I recognize bad design when I see it. I can think of dozens of ways a battery can be made easily accessible by a total klutz, and still be weatherproof. And why didn't they just power the clock off the 12V electrical system like every other motor vehicle on the planet?
You can add the clock battery access to the list of the other things that were obviously designed by Piaggio's crack engineering team on the Friday afternoon before a holiday: the spark plug access and the kickstart.
