after striping and bodywork with differ from usually
yeah... usually people here striping with media blasting or chemical. but I used the easiest way to remove paint and bondo with thermal heat to have the bike stripped to bare metal. I guess this is a cheapest solution
and now I continue with primer, before that I clean it with wet sanding. and primer with nippe200 from Nippon Paint based on epoxy. after primer need a litle bondo over the welded and for a good shape
ps: it're slow going project because I only have weekend time
and still not yet can determine its colour...
