@jozzze2000 avatar
Vespa PK 50(75), PX80(139)
@jozzze2000 avatar
Hello!
I am new to this forum, my first post.
I am from Slovenia EU, I just bought this Vespa PK 50.
And now a question for all of you.
Are horncasts-horn covers compatible between different frames:
-Original horncover for PK frame is
-Horncover for T5 frame is
-Horncover for Lambretta DL, GP
-Horncover for V 50
Since I have to buy a new horncover and due to fact that I don't like PK frame original horncover, I'd rather put on one of three listed above.
I think the main problem would be, if the front body arcs are different.
Does anybody know this?
Thanks for your help.
Best regards, Joze
@hotboxdeluxe avatar
'09 S50, '79 V50
'09 S50, '79 V50
Don't have the answer sorry - I am inexperienced
But I will follow your project with interest, something like what you have is what I'd like to attempt for my first scooter-fixer-upper. I've done a few cars, and I'm itching to rip up and personalise an older Vespa
@rover_eric avatar
@rover_eric avatar
how come you don't like the PK horncast? I love that thing.
If i were you, i would get the dimensions of the stock PK50 one.
See, only certain smallframes had removeable horncasts. ( PK's, 50 special, ....and i don't remember many others ) You want to see what the dimensions are so you can figure out if the PK takes the SMALLFRAME sized horncast ( like the 50 special, which is much thinner than a normal sized P-series ) or if it was built wide enough for a largeframe one...which i doubt.
I sold my PK125, regretably, about 3 years ago and i don't remember the dimensions ...but i thought it was small like the 50 special horncast. You could always try to get one of the 2 different style ones they had for that bike ... the one with the grill slits or the one that looked very much like an old P200, only smaller.
@jozzze2000 avatar
@jozzze2000 avatar
Thanks for replies guys.
I'll think of something when the time is right.
So...back to the project.
First thing that i did was dismounting the engine.
It was pretty greasy.
Then got my hands on welding machine and did this stand for easier cleaning and engine check/repair.
Next thing was cleeeeaaaaninnnng. Mmmm, it looks much better now.
Since there was a little time left, I started to take apart the engine.
Cylinder and piston have a few "scratches", I'll repace them with new ones.
Until next time, Joze
P200e
P200e
Re: My Vespa PK 50 rebuild
Nice stand.
Are the cotouts next to the LH indicator standard?? I can't imagine what they are for?
Keep it up
Wil
@xmanhoe avatar
@xmanhoe avatar
holes
the holes are for the horn as pk has no vent in horncast,You could try to get a horncast off a pk 125 my 125 automatica had one like a mini px vespa try SIP they might do them good luck with the pk i just finished one for my daughter built it from 5 that i had in garage lol if you are stuck for parts let me know good luck bill
@jozzze2000 avatar
@jozzze2000 avatar
so...frame and a few other parts got sandblasted and painted.
Don't have photos yet.
Engine has new cylinder, piston, crankshaft bearings, oil seals.
I would like to replace rubber legshield trim for "chrome metal" look trim like two, http://scootersauce.com/index.php?main_page=product_info&products_id=3237 or http://cgi.ebay.co.uk/vespa-lml-T5-125-150-200-plastic-legshield-trim-silver_W0QQitemZ400068445778QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item5d25f00652&_trksid=p3286.c0.m14.
Does anybody have any expiriences with this trims?
I would reather put plastic trim, because it is easier to mount it.
Thanks, Joze
@xmanhoe avatar
@xmanhoe avatar
TRIM
Hi jozzze2000, try beedspeed.com they have lots of parts for the pk or sip scooter or www.scooter-center.de/ the plastic is easier to fit, cheers Bill
@jozzze2000 avatar
@jozzze2000 avatar
Some photos....
Before:
After:
Front with custom horncover:
Rear with customized SS180 tail light:
Customized SS180 tail light with rubber seal (not being in it's place):
A few other painted parts:
External inline image provided by member with no explanatory text[/img]
@veloce75 avatar
not-so-normal
@veloce75 avatar
not-so-normal
Sick! what's going on with your horncover Wha? emoticon
@jozzze2000 avatar
@jozzze2000 avatar
Horncover is customized to retro look.
@xmanhoe avatar
@xmanhoe avatar
WOW
Hi jozzze, wow that looks great I love the colour , did you spray it yourself? nice job a real credit to you keep up the good work, if you pm me your address i will send you a top tray for the toolbox for free as i do not need it anymore and you can have it.I also have some pk badges in my garage i will send them too ,looking forward to seeing your PK finished Cheers Bill
toolbox tray
toolbox tray
@xmanhoe avatar
@xmanhoe avatar
parts
PS are there any other bits you need as I have some sitting in my garage,cheers Bill
@laclinica1 avatar
many
@laclinica1 avatar
many
hi joz
I'll put a picture of the solution that I have adopted with regard to the carpet mat ..... The wasp is a pk that I restored last year for a girl.
instead of the rubber mat I put the adhesive strips that you use the stairs as slip, shaped and cut
@rover_eric avatar
@rover_eric avatar
that's a clever idea, and looks nice. Well done.
It's painted already, but if you are careful and use a lot of PVA, you can still make a mold from the horncrest, so you can make them and sell them : )
@jozzze2000 avatar
@jozzze2000 avatar
If I knew before, that I would have problem finding floor mats, I would have prepared floor for V50 floor rails.
My floor isn't as flat as I want it to be to use floor rails.
I will have to improvise some how...
@jozzze2000 avatar
@jozzze2000 avatar
Update from last night...
My moto is: Every bid cleaned/polished or replaced.
'09 S50, '79 V50
'09 S50, '79 V50
Excellent! Can't wait to see this all up together 8)
@xmanhoe avatar
@xmanhoe avatar
WOW !!!
Hi Joze, wow that looks amazing!! Love your moto. I will be clearing out my garage next weekend so if I come across any PK bits I will PM you . I still have the tool tray for you, it means I can send them all together.Keep up the good work friend. Cheers Bill ps what are you going to do with the engine? paint/tune etc?
BEFORE I CLEANED MY PK 125s AUTOMATICA ENGINE
AFTER
AFTER
@jozzze2000 avatar
@jozzze2000 avatar
I cleaned the engine, changed piston and cylinder DR 75cc Formula 6 ports. Changed all sealings, bearings, polished kickstarter and painted flywheel. It has new chromed flywheel cover and head cover, some racing spark cable and that is it. I am planning to polish lower part of engine to full shine if I'll have some time during winter time.
Bill, thanks for the look-up for PK bits.
@robbyrivai avatar
Yamaha MIO :P
@robbyrivai avatar
Yamaha MIO :P
who would have tought that old vespa horn cover would look nice on a PK
great Idea man! very sick
@jozzze2000 avatar
@jozzze2000 avatar
Interested think is that no one noticed v50 fender
@koenig_blues avatar
haha since u mention it now i see it clearly Razz emoticon u my friend have a very unique taste and i like ur motto so much keep up the good work and i cant wait to the full result
cheer
ebeth Razz emoticon
@copper_dolphin avatar
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
Thanks for the updated pictures, it really looks like it is coming together nicely. Good luck with the rest and keep us updated...
@xmanhoe avatar
@xmanhoe avatar
fender
I did, I did!! just couldnt rem what it was off lol honest lol
custom px 200, pk 125xl
horn cover
Heya how are you, I have just been searching around trying to find a similar horn cover to the one you have put on your 50, could you tell me your secret? bike looks amazing. I am doing a similar one up myself but it is the 125 model. Boyd
@jozzze2000 avatar
@jozzze2000 avatar
@cgallenger: check your PM.
@nigelthefish avatar
ET2, PX150
ET2, PX150
Damn you've done a nice job! Really impressed!
@jozzze2000 avatar
@jozzze2000 avatar
Thanks guys for all the compliments.
Back to the project...
...engine installed, cables mounted. Joze
@junglizt1210 avatar
Vespa 50 Special, Honda CG125
Hi jozzze,
I was just wondering if you had your frame and parts wet-sprayed (e.g. with a compressor and spray gun) or if it was powder-coated?
The reason I ask is that in my area I can only find a decent company which does powder coating and I don't know anyone who can wet-spray. Problem with powder coating, is that it won't work with plastic. I'm looking at buying a PK and it is needing some restoration work so I'm wondering if you can help me a bit more:
Could you tell me whether these parts are made from metal or plastic?
- rear bumper
- glovebox parts
- headset and handlebar parts
any other parts which are plastic?
Many thanks,
Dan
@bgk avatar
ET2
@bgk avatar
ET2
Paint looks really nice. But I'd have stuck with the entire PK trimmings. The PK is a sharp scooter!
I like what you have done. Sometimes it takes some big balls to do something different and make it look good tops it off. Nice work mate.
@jozzze2000 avatar
@jozzze2000 avatar
Junglizt1210 wrote:
Hi jozzze,
- rear bumper
- glovebox parts
Many thanks,
Dan
My frame and all coloured parts were wet-sprayed. Powder coating is more suitable for brake hubs, fork, rims. I don't think that powder coated frame would look good.
I have marked all plastic parts with red dot. Horncover is plastic too.
If you have any further questions don't hesitate to ask.
Hi jozzze,
Thank you so much. I have visited someone in my town selling a Vespa PK on eBay and obviously I need to think about how I am going to restore it, since it is not in great condition. Did you spray your parts yourself? it looks good!
Looks like I need to find someone who can wet-spray near me then Laughing emoticon
regards,
Dan
pk 50 spcial
pk 50 spcial
hi ill will be following your rebuild as ive just bought my son a pk 50 special for his 16th birthday but we are doing it up any tip and help would be appreciated [/img]
pk 50 spcial
pk 50 spcial
@jozzze2000 avatar
@jozzze2000 avatar
Junglizt1210 wrote:
Hi jozzze,
regards,
Dan
Painting was done by local "afternoon garage painter" that has painting booth.
No problem, all you have to do is ask.
PS: Can anybody guess which car colour is this blue?
@xmanhoe avatar
@xmanhoe avatar
colour
I know the colour!!! only because Joze told me lol so keep guessing cant wait until its finished
@jozzze2000 avatar
@jozzze2000 avatar
Re: colour
[ Time: 0.0202s ][ Queries: 4 (0.0129s) ][ live ][ 339 ][ ThingOne ]
