@bricktop avatar
PX 125...got me a scoot finally!!
@bricktop avatar
Hi all
on my 2nd 125 PX now, this ones 5 years old - both of them only ever started about 25% off the leccy start normally after a long run out, is this a starter, batterty or earth issue???
any ideas, is this a common problem?
regards B.T.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
What is a leccy?
Just kick start that thing
@christos_x avatar
No Scooter no more...
@christos_x avatar
You might want to get yerself over to the 'not so modern' section its where all us geared bods hang out, drink, smoke fags and generally talk bollox.
but as for your starter motor.... could be you've got very little charge in your battery, could be that your starter button is knackered or has a loose connection, could be your motor is on the way out.
its a very well documented fault and most people get rid of the motor when its playing up and just kick the bike over. The first PX I had never had a working lecky (electricalatad for you lot over the pond) start so i ditched it and saved a few pounds in weight. The PX I have now has a working lecky start but was playing up for a while until i stripped the starter button and re soldered the connections, no problems since.
P.S where abouts in Leicester are you mate? me wifes from Ratby and i get to go to sunny Leicester every now and again to get very drunk with mates we have there.
Also did you know that Sir Harry of Barlow (Pro Porting) lives in Glenfield, so if you need any porting work / engine tuning done he's yer man.
@benito avatar
@benito avatar
Moved to Not So Modern.
@big_foot avatar
Scooterless at the moment
@big_foot avatar
I moved to a P200E because I wanted a kick, If it won't start with the electric
start then there are umpteen reasons why it won't work.
Battery is the main one though.
But if your electric start motor isn't in there or not working,
Then that too could be a problem too.
All I got to say is this:
For those of you that know... ROFL emoticon
@big_foot avatar
@big_foot avatar
Sink or swim?
Sorry Eric..couldn't help it again..jez..also followed up with christos x comment..very well done by the way. Just click the link and scroll down:
https://modernvespa.com/forum/topic35965?highlight=pussies
nothing at all
nothing at all
confusious say
mind over matter
if you don't mind kickin it
then the leccy start don't matter
mind over matter Nerd emoticon
jimmyb865 wrote:
confusious say
mind over matter
That was awesome...we are not worthy...we are not worthy!
@christos_x avatar
@christos_x avatar
HA HA HA i remember that ha ha ha
Classic Modern Vespa at its very best Clown emoticon Clown emoticon
HA! It was a fantastic moment! I believe it's in the top 5 of "shit that was very funny around here" for sure. But where you got the image of the damn cat in a prosthetic leg is beyond me. Clown emoticon
@christos_x avatar
@christos_x avatar
Ha Ha all together now...
Cat in a leg, cat in a leg boom boom boom
cat in leg, cat in a leg boom boom boom
cat in leeeeeg, cat in a leg
Clap emoticon Clap emoticon Clap emoticon Clap emoticon Clap emoticon Clap emoticon Clap emoticon
ROFL emoticon ROFL emoticon ROFL emoticon ROFL emoticon
I'm laughing so hard I'm almost crying!
Crying or Very sad emoticon
@bricktop avatar
@bricktop avatar
not too sure whats going on in this thread to be honest, am i the butt of some joke? erm thanks.
yup, i`ve been kick starting it of course, but would like the option to hit the red button, helps when you come to sell the scooter too, like everything works.
@bricktop avatar
@bricktop avatar
Hi christos, i`m in Loughborough, thanks for the heads up on the engine side of things.
@louispain avatar
Cosa and P200E
@louispain avatar
Cosa and P200E
Could be poor charging of the battery from the bike.
Does the starter work properly with a freshly charged battery?
Testing the battery charging.
Get a multimeter and check the voltage of the battery. A good battery should read something like 12.6 volts or higher. If it gives a good reading the battery is fine. Lower it´s suspect or needs charged.
If the battery is low, take it of the bike, charge it, leave it standing for a while and check it again.
Once your sure the battery is good. Put it back in the bike. Start the bike. Connect the multimeter and run the revs up to about 3,500.
The meter should show about 14 volts going through the battery. Try it again with the lights on. If there isn´t a charge of about 14 volts going to the battery the regulator may be suspect. Check it and clean the connections. Test again.
http://www.vespamaintenance.com/elec/charger/index.html
Nah mate..we are just pulling your leg... Clown emoticon
It sounds like a battery issue or grounded out wire somewhere.
[ Time: 0.0164s ][ Queries: 4 (0.0086s) ][ live ][ 343 ][ ThingOne ]
