Also the rollers I took out used to be orange the ones I fitted are black any difference (apart from colour)?
As some of you may know I have been planning to change the belt and rollers on my Vespa ET4 50 for some time now. Today I finally got round to it though it took a bit of work I got it done all seemed fine until it came to testing it the starter motor just locked up each time I tried it
Also the rollers I took out used to be orange the ones I fitted are black any difference (apart from colour)? |
Posts: 6897 Location: GT, Texas |
You may have pinched the belt between the variator halves, which would prevent you from completely tightening them together, subsequently causing the outer half to rub against the transition housing when re-installed.
It is tightened up as much as it was before but I may have trapped the belt somewhere. Would this prevent it starting?
Posts: 46114 Location: Pleasant Hill, CA |
Yes.
You have to 'untwist' the clutch to make sure the belt is well stuffed down inside the driven pulley halves. Then you can do the variator up just fine. |
Gobshite Shiva
Posts: 14960 Location: London UK |
check out this wiki article: https://modernvespa.com/forum/wiki-gts-300-jcosta-installation
the instructions are for a GTS, but if you scroll down you'll see two pictures showing how to get the belt properly down inside the halves of the driven pulley, and what it looks like when it's correctly seated. the principle is identical for your scooter. make sure you orient the belt in the right direction too |
NOOO!! just opened up the side casing to find the belt fitted backwards
No, do not just loosen the nut. You need to get the belt further down in the clutch pulley groove and further out of the drive pulley so it's loose when you tighten the nut. Once the nut is tight you should still be about to move the belt around in the front pulley. Does that make sense?
Wayne B |
MR. MOPHEAD wrote: NOOO!! just opened up the side casing to find the belt fitted backwards If you loosen the variator nut you will absolutely, without a doubt ruin your bike--the crankshaft will be damaged and you will require a complete engine rebuild. As others have noted, you have pinched the belt in the variator on assembly. You must remove the nut, remove the outer variator half, and remove the driven pulley. You must make sure the belt is deep inside the driven pulleys in order to have enough slack to install the outer variator half. This would be a good time to make sure the belt is oriented correctly (arrows point in direction of travel). Put the driven pulley, clutch side down. Push hard on the lower pulley and shove the belt as deeply into the gap as possible. This is easier with two people--one separates the pulleys while the other shoves the belt in deep. Make sure the belt doesn't slip out as you reinstall the driven pulley. Now you have plenty of slack for the outer variator half to go on properly. On the GT and GTS there is a washer that goes on the shaft before the outer variator--I'm not sure about the LX, but I'm guessing yes. Install the outer variator half. Install the two outer washers (big first, then small) and tighten the nut to the correct torque. This is important, so use a torque wrench. Now everything should move nice and easy (accounting for engine compression, of course). It is a good idea to mark the position of the variator nut relative to the shaft with paint or a Sharpie®, so you can be sure it doesn't move after you've run the bike a while. Good luck, P. |
If I may add that the nut should be replaced because it is a "one time stretch" fastener. Especially since the OP admitted to over tightening the nut and that is evidenced by the distorted hex in the pictures.
I have removed the nut completely to switch the belt round but I'll get a new one before re-fitting. Is the driven pulley on the left? I'm not sure I overtightened the nut that was just a suggestion as to why it wouldn't start. What is the correct torque for the crank nut? The sharpie is a great idea which I will definatly use when I next reassemble it. How can I seat the belt deep in the pulleys but not pinch it? There wasn't a washer between the variator halves when I opened it.
Also is it completly necessary to remove the clutch bell aswell as we managed to fit the belt in quite well with it fitted before surely we can just ease the belt up or down as necessary? Sorry I know I have asked alot of question I just want to get this sorted so I can enjoy the good weather this turns out to be far more difficult than I expected. Thanks for all your help so far.
Gobshite Shiva
MR. MOPHEAD wrote: I have removed the nut completely to switch the belt round but I'll get a new one before re-fitting. Is the driven pulley on the left? I'm not sure I overtightened the nut that was just a suggestion as to why it wouldn't start. What is the correct torque for the crank nut? The sharpie is a great idea which I will definatly use when I next reassemble it. How can I seat the belt deep in the pulleys but not pinch it? There wasn't a washer between the variator halves when I opened it. you also need to make sure that you've pushed the drive pulley assembly as far back against the crankshaft spline as you can when you put it back on. this is a bit fiddly and may require bit of wiggling around (of the assembly, not you). check out this thread for what can happen if you don't: FUBAR Final. Pictures of How not to work on your CVT. |
Right thanks again genie I think I've got it now. So i have to pull the two plates of the clutch (which are on the right held together with the spring) apart so I can then push the belt in as far as possible. This will then give me enough slack on the left at the drive pulley to move the belt away from the center of the two variator halves so I can seat them tightly together and well onto the crank shaft then using a new crank nut tighten it all on using a torque wrench (Still unsure how tight it should be) I will post up some more pics before i close it all up to make sure I've got it right third time lucky hopefully . This time I will photograph every stage very clearly and post them up so nobody else encounters similar problems.
P.S I will mark where the nut is on the crankshaft with a sharpie then check up on it in a few days or after a few miles to make sure the nut hasn't backed off. Great idea Paul G. |
Gobshite Shiva
yup that's about right though i think it is the clutch nut that needs replacing each time.
for the correct torque you'll need to go to the manual - which i believe you will find here, thanks to jimc http://www.wotmeworry.org.uk/manuals/ET4/ |
Posts: 8758 Location: Annapolis, MD, USA |
genie wrote: yup that's about right though i think it is the clutch nut that needs replacing each time. for the correct torque you'll need to go to the manual - which i believe you will find here, thanks to jimc http://www.wotmeworry.org.uk/manuals/ET4/ |
Gobshite Shiva
ah, cheers. how does one identify a 'single use only' nut? is there anything specific about the nut itself or is it just a matter of where it's located?
i've been using loctite |
genie wrote: ah, cheers. how does one identify a 'single use only' nut? is there anything specific about the nut itself or is it just a matter of where it's located? i've been using loctite |
