This is a safety issue because the lack of resistance on the the throttle combined with the tendency to slip on the nice leather GTV 250 seat has frequently created a problem. When I crack the throttle I begin to slide back in the seat, and with almost no resistance the throttle rolls open more as I slide back. The scoot accelerates more, I slide back more, the throttle opens more ...
I have found I can only really stabilize myself on the 250 using my left hand. The throttle grip twists far too easily for me to use my right hand for much steering input. The throttle takes up a lot of the movement and instead of applying force to the right handlebar for steering I end up mixing in unwanted throttle input.
I've looked at the throttle body and I don't immediately see a spring adjustment but it's mighty tight down there.
