@kylesalter avatar
vespas, lambrettas, cushman, and mopeds
@kylesalter avatar
i have between 95 and 100 psi compression. that about right?
stock everything on a 74 sprint
@rover_eric avatar
@rover_eric avatar
Is it RIGHT? Eh ...it will run
A brand new, properly gapped top end will net you around 120. Your bike will altogether NOT run at like 80-85psi.
You're on the lower end of the spectrum, but the bike will work fine and start up readily. You just won't have all the power it's capable of.
*edit* did you measure that hot or cold ?
@kylesalter avatar
@kylesalter avatar
wow it runs like a top and again other sprint it kills them. top speed is 60 to 62 mph.
Are you sure it's not KPH? Razz emoticon
@kylesalter avatar
@kylesalter avatar
nope psi
nothing at all
nothing at all
try another comp. tester
that performance is impossible from a low end compression
you have to remember the high pressure is what helps the ignition
it is the POWER in the POWER band.
i may be wrong but doubt it
@koenig_blues avatar
+1 cant agree more, higher comp higher performance while low end comp low performance Razz emoticon
[ Time: 0.0097s ][ Queries: 3 (0.0024s) ][ live ][ 341 ][ ThingOne ]
