@guynamedaleck avatar
Allstate Super Cruisaire
My Allstate was fine when I rode it home yesterday, then this morning I got on it to go to work, and it started up just fine, and sounded like it was running well, but I turned the handle to give it some gas and nothing happened. Also, there was no longer any resistance in the handle. I'm assuming that the throttle somehow disconnected. Does that sound right to you guys?
I didn't have time to mess with it this morning. Once I am able to start poking around, what do I need to be looking for?
@hojo1690 avatar
1980 P200e, 1956 ACMA, 1979 P200e, 1974 Ciao
@hojo1690 avatar
Re: My throttle has disconnected??? I'm not sure
Sounds like your throttle cable snapped. Look where it enters the carb, and twist the handle. If nothing moves, you need to replace your cable.
@rover_eric avatar
@rover_eric avatar
If i had to bet, i'd guess it popped out of the little pulley inside the headset. If it's not held with some tension it does this often.
Tighten up the tensioner on the outside of the carb box after you get it hooked up again.
I checked everything out and the cable did in fact break. What I don't quite understand is how that happened while I wasn't riding it. Unless it happened to break with the very first pull of the throttle when I started it in the morning. I guess I should be thankful that this didn't happen out on the road.
Anyways, I'm gonna take it by my mechanic after work, and he'll take care of it.
nothing at all
nothing at all
try having it stick while on the road
now thats a eye opener
@christos_x avatar
No Scooter no more...
@christos_x avatar
Do it your self and save a few bob, it aint hard and you'll learn a thing or two for when it happens in the middle of nowhere when no one can hear you scream
@joshzingzing avatar
if a cable snaps in the woods
and no one hears it snap
did it snap
one for you splinter -------------- cowabunga dudes
@mdchanic avatar
GS 160 /4
@mdchanic avatar
GS 160 /4
did it snap
No.
Not until you jump on your bike late for an appointment and find it has snapped.
- Eric
@rover_eric avatar
@rover_eric avatar
did it snap
Are these scooter koans?
*closes eyes and meditates*
Does a smallframe have buddha nature?
I did not actually hear it snap, nor was I riding it when the alleged snapping occurred.
Perhaps it never snapped at all, and the broken cable that I pulled out was the physical manifestation of my uncertainty in regards to performing my own scooter repair...
Schodinger's throttle cable?
nothing at all
nothing at all
this is like vu ja de
that feeling that you've never been there before Nerd emoticon
[ Time: 0.0117s ][ Queries: 3 (0.0055s) ][ live ][ 343 ][ ThingOne ]
