@napadave avatar
Fly 150
@napadave avatar
Fly 150
What is the reason for the extra piece inside the fuel neck the turns. I thought it may pull up to aid fueling but it does not pull up, but you can spin it around in the neck of the tank.
@danifly avatar
09 Triumph Bonnie, 06 Kymco P250, (Retired: 05 Stella , 08 Piaggio Fly150, 02 Yamaha Vino50, 07 Yamaha C3)
@danifly avatar
Can you be more specific?
What part are you talking about? (Pictures always help)
@napadave avatar
Fly 150
@napadave avatar
Fly 150
When you screw off the fuel cap, it is inside the neck of the tank. It will turn but will not pull up or out.
@silver_streak avatar
I think the intent of that plastic sleeve inside the filler neck is to control the level at which the automatic shut-off triggers on the fuel pump, so that the tank doesn't overfill and send gas into the vapor canister.
Although I haven't had a problem filling my LX (pumping slowly), by many accounts it doesn't work so well.
@napadave avatar
Fly 150
@napadave avatar
Fly 150
I once thought it may be to do with shutting off the fuel nozzle, but it has some different design/shape to it around the inside that makes me think something else?
@napadave avatar
Fly 150
@napadave avatar
Fly 150
Nobody Knows?????
@zippy avatar
Dragon Red LX 150 (Hillary)
@zippy avatar
I think its there to make the nozzle sit properly in the neck during
refueling. On my LX it works great if you hold the nozzle at a slow speed.
Paul
Is it green?
@napadave avatar
Fly 150
@napadave avatar
Fly 150
judy wrote:
Is it green?
No it is not green?
It seems odd the would have the kind of design on the inside edges that would have no bearing on holding a fuel nozzle. And why would it turn?
[ Time: 0.0095s ][ Queries: 3 (0.0017s) ][ live ][ 341 ][ ThingOne ]
