Not that you have enough of it showing to do this, but in my experience with stuck cotter pins it's also easiest if you cut the loop end with wire cutters, and then work at pulling one half of the pin out only with needlenose pliers or whatever. Once one half is out, the second half comes out like butter.
EDIT:
On the same topic, do people know why ScooterMaintenance recommends wrapping the cotter/split pin OVER the axle rather than around the castle nut?
The
accompanying text (Step 11)reads:
Bend the split pin as shown to assure your safety on the road. DO NOT LEAVE THIS PART OUT! You may need to clip the split pin to make it fit the way it is shown.
The only thing I can figure is that by doing this the loop end of the cotter pin actually fits in more snuggly into the nut, lessening the chance of it moving about, and wrapping it over the axle keeps it snug. I don't otherwise see why it would be more safe than wrapping around the nut that I've seen in almost every other application of a cotter pin.
Any ideas?
