I decided to try the Giannelli Iperscooter. There isn't much information out about this pipe. I spent many hours searching MV and other scooter bulletins, but didn't find much except one post in Italian that I couldn't read. The Giannelli web site www.giannelli.com doesn't provide a spectacular amount of info on this exhaust either, but shows that they build some quality items.
The one good post I did find was on MV by member juan from Florida posted on October 20, 2008. He does a good bit on the installation. https://modernvespa.com/forum/topic36678
I've only just installed it and ridden up and down the alley (it's raining), so I'll share initial opinions as well, and follow up with some road experiences later.
Cost was exactly the same as the LV from Scooter Trap. No additional shipping charges. I ordered from Matt on Tuesday morning and it arrived this (Friday) morning. Good service.
It's a solid, well-made exhaust - very equivalent to the LV in materials, construction and finish. It's shorter and lighter than the LV - 17" long vs. 22" for the LV. I didn't have a scale to weigh them, but I'd say the Giannelli weighs quite substantially less - perhaps 30% less. It's about the same diameter and sectional shape, so it's really very much like a shortened version of the LV in overall shape and design. The mounting plate is bare brushed stainless, and very similar to the LV mount, but not painted. The LV has a cleaner looking sphincter, with it's smooth little baffle cover, while the Ginnelli looks a little more like a liquid cooled machine gun.
Installation was very easy. The hardest parts, as usual for exhaust changes, were accessing the right hand side exhaust nut and replacing the wire tie on the Lambda probe harness. Unlike the LV, the Giannelli has a one-piece, full length exhaust header included, so it is far easier to mount and align properly. There is much more clearance between the pipe and the water pump, and you can still easily access the oil filter and drain.
The Giannelli seems to sit in about the same spot and at the same angle as the LV, but because it's so much shorter, it starts a couple of inches further back and ends a few inches further forward than the LV. I've no worries about it hitting the bodywork, since it rides just like the LV.
I realize that I'm probably biased now (why should my shit stink?), but I think it's a better looking pipe than the LV. I liked my LV when I was sitting on it, but when the bike was parked on the center stand it did look like a donkey dong hanging off the side. Because the Giannelli is shorter, but also because the head shield breaks up the line and gives it a fatter/faster appearance at the end, it avoids the donkey dong look. The Giannelli has better proportions for the shape and size of the scooter, I think. As you can see, the head shield is anodized aluminum. MV-er juan's was a black wrinkle coat painted finish, and I didn't think that looked so good. I like the anodized piece.
It sounds very similar to the LV, but, as reported elsewhere, slightly throatier and sharper. So far I would say it is no louder than the LV, which is good in my opinion.
Performance? Who knows without a dyno? I expect it performs nearly identically to the LV, and I'm not worrying about changing my Power Booster settings or disconnecting the battery to reset the ECU. I'll take it for a ride tomorrow after it dries up and follow up with a report.
Newly added road test -- Okay, it cleared up and I went out for 20 miles of mostly country highway through the farm fields toward Tonganoxie. As I expected, it's virtually indistinguisable from the LV in performance, operation and, for the most part, sound. After 30 mph you don't really hear it unless you lay hard on the throttle. As I said earlier, it is a little sharper in sound--maybe a tiny touch louder than the LV, but maybe not. If the exhausts were magically switched mid-ride I might not notice the change. I'm very happy with it so far. I'm glad to see some other Giannelli users chiming in. The name is very Italian-y and hep sounding as well. What's not to like?!
⚠️ Last edited by dougw on UTC; edited 2 times
