jimc wrote:
No special tools, but do make sure that all traces of the old gasket are removed and the pipes are clean and smooth. The gasket (graphite collar) is designed to allow the pipes to slide relative to each other to compensate for expansion. The newer ones are only half covered in graphite leaving wire mesh exposed at the other end - the graphite bit is the end that is inserted first into the silencer.
Thanks again to both you and Benito...I checked underneath the scooter, and sure enough, I can feel exhaust puffing out from where that gasket is. I just ordered a new one from Athens Scooter Co., although I'll probably have the folks at Capital City Scooters swap it out. They told me they had another Vespa come in with the same problem...AND the blown-out rear brake line, which you guys saved me from.
I can't say it often enough...this forum is an amazing resource, due to moderators like you. Thanks!
P.S. Why the heck is that sleeve called a gasket? I always thought a gasket was a seal
between two surfaces, not straddling them...
