Locking torques (N*m)
Muffler arm clamping screws 27 ÷ 30 Rear
wheel axle nut 104 ÷ 126 Shock absorbercrankcase
attachment bracket 20 ÷ 25 Lower
shock absorber clamping screw 33 ÷ 41 Nm
Rear brake calliper fixing screws 25 ÷ 30 Nm
That's all from page 47 under "Refitting the Rear Wheel". Four questions:
1. Is that wheel axle nut ACTUALLY 104 Nm? or is that Foot lbs?
2. The reason I being a "Torque Newbie" ask is because my wrench has one side that is in the range of 10-150 foot lbs and the other is 1.4-20.7 Nm BUT SAYS IT IS MEASURED IN KGM. Perhaps this means that I should use it set to between 10.4-12.6(instead of 104-126). But if that's wrong, I guess this wrench won't do it, but since all the others are so low and actually SAY Nm, by them, I figured it might be a typo. Anyone know?
3. I guess this is actually two questions but, does the manual mean 104-126 Nm when it has the "division" symbol? or is that some torque lingo I don't know.
4. Sorry, last question, so when using the torque wrench, do I basically set it to the appropriate torque and then turn it as hard as I can or does it basically get to a tightness and 'spin' similar to a chuck on a drill?
THANKS TO ANYONE WITH EXPERIENCE WHO CAN HELP . I'm sure there are others who are interested in finding out how to properly torque their bolts...
⚠️ Last edited by luthorhuss on UTC; edited 1 time
