@milobscootin avatar
08 GTS 250 Dragon Red
does anyone know how much the bar ends weigh? I assume they are 14oz, but cannot confirm. I have the top case and bar ends, but I'm not sure it will be worth it to upgrade to 17oz. (hvmp)
http://www.hvmp.com/vespa.htm
@tb avatar
@tb avatar
http://www.jettin.com/ProductsPage.htm
You could also consider the Jettin bar ends...they have a 15 oz.
@snapshot05 avatar
WHOoligan
WHOoligan
@snapshot05 avatar
Re: Weight of bar ends for GTS topcase?
Yes they are worth it, I have a pair, they even help after you take off the top case with the front end shake.
thanks. I'll order them now- more money out of my bank account for scooter related purchases.
@snapshot05 avatar
WHOoligan
WHOoligan
@snapshot05 avatar
Glad I could help. Your scooter addiction can be costly, but worth it.
Manny
@paul_g avatar
GTS 250ie
@paul_g avatar
GTS 250ie
Fine a postal scale. Weigh the bar ends.
Now you know what they weigh.
P.
The bar ends that came with your bike weigh 9.5 oz. I know that because I weighed 'em.
If you weigh the heavier Piaggio bar ends that came with your top box please let us know--information is king
P.
thanks, I agree info is king. I asked my shop if they knew the wt of the bar ends that came with the top case. If I don't hear from them, I will weigh them myself.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
OEM supplied with OEM topcase are 16oz. OEM standard are 9.5 ounces apiece.
That and they contribute more
to the beautiful chromed shininess of your scooter
+1
@pdxscoot avatar
BV500 - GTS250
@pdxscoot avatar
BV500 - GTS250
Heavier is better. We have the HVMP ones and would highly recommend them over the ones from Piaggio when you buy the top case.
Thanks, the order is in. Just to clarify, I have the Piaggio top case with bar ends now. I wanted to make sure the HVMP ones were heavier than current model I have, so I don't waste $.
I'm also trying to also figure out how to get the backrest pad from 300 top case to swap my current top case pad - to match the 300 seat I'm going to get.
@snapshot05 avatar
WHOoligan
WHOoligan
@snapshot05 avatar
I had the topcase bar ends but after adding the Hvmp ends, the wobble is even less of an issue, sure its only one ounce, but it seemed to work for me.
Thanks L.
@pdxscoot avatar
BV500 - GTS250
@pdxscoot avatar
BV500 - GTS250
I don't know the actual oz difference between the ones that came with the Piaggio top case and the HVMP ones, but I assure you they are heavier and they improved the high speed stability. I couldn't get my wife to ride over 55 until we got these installed. It is worth the $$.
@ken_photo avatar
'07 Vespa GTS250ie
@ken_photo avatar
'07 Vespa GTS250ie
If one has heated grips will it be a problem adding heavier bar ends?
[ Time: 0.0137s ][ Queries: 3 (0.0024s) ][ live ][ 341 ][ ThingOne ]
