@kdude avatar
@kdude avatar
How did you guys access the left side shock on the air filter side to do a two notch adj. ?
Do i take some stuff apart to get to it ?
thx,
Hp
@woodenhead avatar
GT60
@woodenhead avatar
GT60
If it's the same as the GTS you just do it one notch at a time. It's a bit awkward, so some people suggest wearing a glove the first time . Best to keep both shocks at a similar setting as you adjust it, so as to not make the second shock more difficult to adjust.
cheers
@kdude avatar
@kdude avatar
cheers
damm... thats why i can't budge the left side.. i moved the right side shocks up to notches ..
Adding pre-load to one side should make it easier to adjust the other, Shirley?
For the left side - can you take the pet-carrier out? It may give you another angle of attack.
@trowel_and_cuffs avatar
YOu can also remove the lower cowl pieces. just 2 screws one front one rear. pops off and gives a slight bit more room.
[ Time: 0.0085s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
