Does anyone know if a side mounted kickstand is available anywhere for the US version of the GTS 250? I'm told by my local dealer that the side mount kickstand is only available on European Vespas and is not available in the US, and I don't understand why. His explanation is that the frame on the US Vespas is different from the European version. I think that I'd much prefer to have a side mounted kickstand instead of the stock center kickstand. Probably some US requirement due to some silly lawsuit or something like that. Thanks.
Sidestands are available. Contact Motorsport Scooters, a forum sponsor. The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. Be forewarned if you do get one, its position, (as compared to motorcycles) are far forward on the bike, not under the center, fore to aft. You have to use your heal and push out and away from you to deploy it, and then keep your foot pressed on it until the weight of the bike stops it from snapping back.
You'd be wise to only use it for temporary situations, on level surfaces, and hard ground. Otherwise, you WILL have to pick up your bike someday after it has fallen over. The center stand is much more stable. |
We have a side stand on our GTS. Unless you like the idea of your scoot laying on it's side, I recommend saving your money. It is a bad idea. It is very unstable.
volosong wrote: Sidestands are available. Contact Motorsport Scooters, a forum sponsor. The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. Be forewarned if you do get one, its position, (as compared to motorcycles) are far forward on the bike, not under the center, fore to aft. You have to use your heal and push out and away from you to deploy it, and then keep your foot pressed on it until the weight of the bike stops it from snapping back. You'd be wise to only use it for temporary situations, on level surfaces, and hard ground. Otherwise, you WILL have to pick up your bike someday after it has fallen over. The center stand is much more stable. |
I use my side stand all the time. My backyard patio has an uneven cement and is small area to park, so it's easier to have it on the side stand all the time at home. It hasn't fallen, and I haven't dropped it in a year. knock on wood.
I also use for it short shopping trips, coffee shop, farmer's market, etc. However, we don't have asphalt that melts here in the bay area, but we do have hills, so when at work, or parked for long periods of time, I use center stand. |
WHOoligan
Posts: 6695 Location: Los Angeles Kings, Stanley Cup Champions X2 |
WHOoligan
I bought my sidestand from Motorsports, and I love it. I use it daily and Im glad I bought it.
You gotta use a little common sense when using it, and after you learn how to deploy it its a snap. I havent ever had the problem of pant legs catching, but then I dont wear bell bottoms. paint it to match the color of your scoot, I painted mine silver to match my scoot. I think your dealers wrong about the frames being diff. Good luck Manny PS not too difficult to install either. |
I put a side stand on my LX 150 and I never use it where someone might bump the scooter. It pops up way too easy.
About the only place I use it is in my garage or for a very short stop. I use it in the garage because the floor is so slick the center stand just slides when I try to get the scooter off of it. |
Posts: 2836 Location: Raleigh, NC |
If you install your sidestand with only one of the springs, it will be less inclined to retract unexpectedly.
I've owned motorcycles since the mid 70's that have had this type of stand and have used them frequently with no problems. A little common sense and awareness will go a long way when using the sidestand. Presently, we have them on a GTS and a GTV and in fact, we leave them parked in the garage on the sidestands when we're not riding. If we park somewhere for more than a couple of minutes away from home, we always use the center-stand because the scooter can be pushed over easily when it's on the sidestand. Just be very aware of where and when you use the sidestand and I think you'll find it to be a great accessory for your scooter.
It's always fun when its on the side stand and a dumb ass friend doesn't realize its a CVT... decides to give it the old rev-a-roo.
It is kinda nice on really long rides, lots of gas fill ups, with gear... to not have to pop it up on the center stand every 80 miles. I've also used mine in traffic jams, or slight up hills when sitting for awhile, holds you in place well. =) |
volosong wrote: The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. |
starreem wrote: If you install your sidestand with only one of the springs, it will be less inclined to retract unexpectedly. I was on a ride a couple of weeks ago following a vintage Vespa when I saw something come off his scoot and go bouncing across the road. He pulled off and I told him about it. He said he heard something come loose but everything was still working. I told him what it looked like and he said "Oh that's the spring holding the center stand up No big deal" He put a bungee cord on it and away we went. |
Dutch wrote: I put a side stand on my LX 150 and I never use it where someone might bump the scooter. It pops up way too easy. About the only place I use it is in my garage or for a very short stop. I use it in the garage because the floor is so slick the center stand just slides when I try to get the scooter off of it. My brother (who is well versed in this stuff) told me to put my right foot on the ground in front of the center stand and then to roll it forward...your foot acts as a "stop". Things to make sure of...do not apply the brake, let it roll and get your foot out of the way! You can then mount the bike...or (since I have a side stand)...I engage the side stand...turn the wheel left...mount the sccot carefully (you don't want it to pop up until you're ready)...right the scoot...up pops the stand and you're set to go. |
Posts: 45909 Location: Pleasant Hill, CA |
Motorsport Scooters wrote: volosong wrote: The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. I'm wondering if the GTS sidestand could have the top spring hook point moved so that the stand stays put when the bike is pulled upright. If it could be done, I'd also want to add a switch into the kill-switch circuit mark ewe... |
starreem wrote: If you install your sidestand with only one of the springs, it will be less inclined to retract unexpectedly. Those springs are what hoilds that sidestand UP while you're riding! So I like having two... |
Posts: 5707 Location: Santa Cruz California |
Does the aftermarket, non piaggio, side stand offered from Scooterwest.com have the same problem with popping up unless its supported by the weight of the scooter as discussed earlier in this thread wrt poor support? THx. Miguel
Dutch wrote: I'm pretty sure that's where mine came from. |
Thanks everyone for your responses - I appreciate them all. I still think I favor a side kickstand, but as some suggested, one just has to pay attention to what they are doing when parking the scooter using the sidestand. Have not purchased one yet, but have checked them out on the website of the place that sells them, and will be purchasing one to use. Have checked underneath the scooter on the frame, and the bracket is already welded in place - all that needs to be done is to bolt the kickstand into place and install the springs. I didn't like the suggestion to use only one spring, either. If it's designed for two springs, there must be a reason - if only for safety in case one of the springs broke there'd be the other one left to still hold the stand up out ofthe way so it wasn't dragging on the pavement.
Again, thanks all for your input. Once I finally get one and install it, I'll come back to this topic and give my opinion on it!!! |
'09 S50, '79 V50
Posts: 2105 Location: Heidelberg, Germany |
Ron wrote: Thanks everyone for your responses - I appreciate them all. I still think I favor a side kickstand, but as some suggested, one just has to pay attention to what they are doing when parking the scooter using the sidestand. |
Beer Fairy
GTS-"Cannonball Bettie" Member Iron Butt Association
Posts: 851 Location: Seacoast New Hampshire USA |
Beer Fairy
Here we go again.... not
At first, I thought this was going to be one of those, Here we go again threads , but I must commend all of the posters for carrying on a civilized, pro vs. con discussion. Good information backed by facts and experiences. Kudos 8)
oh and cheers! ride safe all, look out for the other guy... |
Like I said before I'm very careful where I put the scooter on the side stand.
I'd never leave it in a parking space where it might get bumped or in the library lot where some kid might decide to sit on the seat. But in and out of the coffee shop in the morning I'm fine. |
Motorsport Scooters wrote: volosong wrote: The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. |
volosong wrote: Motorsport Scooters wrote: volosong wrote: The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. |
WHOoligan
WHOoligan
Installed my side kickstand yesterday, and think I will like it. Installation was a breeze. Took longer to get out my tools than to actually bolt it on! Yes, it is obvious that the scooter is more prone to falling using a side stand, but still think I will prefer it to the center kickstand.
Re: Side mounted kickstand for GTS 250?
Ron wrote: Does anyone know if a side mounted kickstand is available anywhere for the US version of the GTS 250? I'm told by my local dealer that the side mount kickstand is only available on European Vespas and is not available in the US, and I don't understand why. His explanation is that the frame on the US Vespas is different from the European version. I think that I'd much prefer to have a side mounted kickstand instead of the stock center kickstand. Probably some US requirement due to some silly lawsuit or something like that. Thanks. |
I put one on my GT, and it works great. The bike won't just leap up and fall over, and the side stand won't retract on a whim. As has been said before, it just takes a little common sense.
I probably would choose to use the center stand if I were leaving my scooter unattended in public, just in case someone decided to move it or sit on it without my permission. You also have to make sure the side stand is fully extended forward before leaning the bike's weight onto it. It's a convenient accessory. |
side stand on GTS
I bought a side stand from Motorsport and have been using it daily for about a year. I prefer it over the center stand - it's faster to use. I did install it with only one spring. After scraping it on a turn, I bent the part that sticks out upward, closer to the scooter bottom, and haven't scraped it again.
Quote: My bike has wires that extend down to the side stand, but have the ends sealed up so it's not connected to anything. So it looks like most of the stuff for the kill switch is already set up. Weird that they wouldn't just provide a kill switch like everyone else... |
XLR8 wrote: Quote: My bike has wires that extend down to the side stand, but have the ends sealed up so it's not connected to anything. So it looks like most of the stuff for the kill switch is already set up. Weird that they wouldn't just provide a kill switch like everyone else... Huh. |
Quote: The temp sensor is right by/in front of the sidestand? Huh. |
GTS250 - GT200 - XJR1300
Posts: 1424 Location: SW London, UK |
CafeMoto wrote: The bike won't just leap up and fall over, and the side stand won't retract on a whim. I do agree that they're fine if you have to park on very uneven ground where you can't use a centre stand or if you're parking where other people can't accidentally bump into it. Must admit I always use the centre stand - with practise it's very simple to use. |
Posts: 16295 Location: Toronto, Canada, Fort Lauderdale, Florida |
I had a side stand on my GTS 250, I so seldom used it because my GTS almost fell over once while on it, I got paranoid and didn't continue to use it. When I picked up my new Super, I decided to leave the side stand on the old bike and not transfer it to my new bike.
RIP
I have the Buzzetti one from Motorsport on both of my scooters. The LT only has the side one since the center one got trashed. Been using it for almost 3 years and no problems. Use common sense and also over time they lose that quick retraction that it had when new. Great to stabilize the scooter when you have it loaded up with groceries. Easy to install i would get it.
Motorsport Scooters wrote: volosong wrote: The story is that they are not "safe", so the DOT required them not to be installed on U.S. bikes. Miguel |
Miguel: Piaggio makes a sidestand that stays down until you raise it and that is connected to a cutoff switch. I have one on my BV500.
This stand is mounted differently and looks different, when compared to the GT/GTS/GTV sidestand. There is a thread or two on this forum where someone took a grinder to the swivel part of the stand and made it stay extended when it was down but they didn't tie in the kill switch. You could probably look at the electrical schematic for the BV500 and see how they have wired the sidestand if you wanted to do this on your scooter. Frankly, I don't really have a problem with it springing back up on the GTS or GTV and have never come close to having a scooter or motorcycle fall over when using this type of sidestand. The first BMW that I ever bought in 1976 had a flimsy sidestand that would spring back, just like the accessory stand for the Vespa (except, the Vespa stand is much more sturdy). BMW sold a lot of motorcycles with these stands and a lot of buyers complained but I saw a lot of Beemer riders use these stands when I would attend gatherings and never saw one fall over. If you're careful and deliberate when using the Vespa sidestand, you'll probably never encounter a problem. |
