Hello everyone,
I'm new at this forum as I recently bought a 2003 Vespa Px125. I've been loving the ride - it's my first scooter but I think I will stay on the scooters side now I've tasted it(specially in terms of passing through traffic, I live in Paris and there's always a lot but with my vespa those days are over).
I just have a couple of questions and if some of the forum experts could give their advice I would greatly appreciate it:
The first one is: I know (now) that I should use a 2 stroke synthetic oil for my vespa's engine (it has a separate tank for the oil) nevertheless, before knowing this I filled the tank with a 4 stroke oil and I would like to know if I should change it for 2t oil???
In regards to this - sometimes when the engine is cold there's some smoke coming out of the exhaust pipe and in 1st gear it accelerates faster than normal up to some point when it actually looses power (so I have to change to 2nd gear). I'm not sure if this problem is mainly oil related, or if the air filter could be dirty too.
The second question has to do with oil too, but for the gearbox: how can I actually check the level and how to fill it up if necessary?
And the last question: a couple of weeks ago I had some problems with the electric ignition and the klaxon - they stopped working and I found out it was because there was a loose cable in the engine side. I reattached it with a new screw and everything was fine until yesterday that both suddenly died (klaxon and starter) the cable is still well attached and the battery has juice so I think there could be a burned fuse or something??
Thanks a lot for your help guys!!
btw here's a pic of it:
Cheers!!
