'08 Piaggio Fly 150
'08 Piaggio Fly 150
Just discovered a nail in my Fly 150's rear tire, so I'm going to have both front and rear replaced (stock Chinese tires on there now). The shop is recommending Michelins. Suggestions?
Thanks, guys!
-- Laura
@copper_dolphin avatar
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
I have not tired tires from them yet, but there are several posts on here about the different brands of tires, and how well they ride, and wear... do some searching and you should find the info you need to decide what tire to go with for your scoot.
@oneprairiepiston avatar
LX150
LX150
Hey Laura....
I just had the same question last week (great minds ).
Here is the discussion:
https://modernvespa.com/forum/topic49241
In short there was lots of love for the Heidenau tires -- but that is kind of a pain for me with availablity.
I am having the Michelin Pilot City put on tomorrow.
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
The stock cheng shin tyres are fine on the fly even in the wet I would fit the new tyre on the front wheel and have the old front tyre moved to the back , why waste money
@silver_streak avatar
I have the Michelin Pilot City, and I really like them. Seem to be wearing well also.
'08 Piaggio Fly 150
'08 Piaggio Fly 150
Thanks for the advice, guys. I read through some of the other threads as well. Think I'll go with the Michelins. I'll give you a ride report soon!
2003 ET4, 1972 Primavera
the front and back tires are not the same size
on modern Vespa and Piaggio
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Tell that to the fly owner with 120/70-12 tyres front & rear
& piaggio typhoon 120/90-10 front & rear Razz emoticon
'08 Piaggio Fly 150
'08 Piaggio Fly 150
I ended up going with Continental Zippy 1's on front and rear (shop didn't have Michelin's in stock). Now, my question is, are the tire inflation pressures the same on the Zippy's as on the Chen Shin's they replaced? I'm assuming I should always go with what the glove box sticker says. Advice?
Thanks!
Laura
Thanks!
Laura
use the same press as you were using.
'08 Piaggio Fly 150
'08 Piaggio Fly 150
old as dirt wrote:
Thanks!
Laura
Thank you! Will do.
I stock my own tires since I bought the scooter. Dealers don't ever stock what you need and are usually over priced on tires too. So I get all my tires from www.MotorcycleSuperStore.com and keep a rear and a set of fronts in the basement. Ride the scooter everyday, so I try and plan for as little down time as possible.
Wayne B
@ronin avatar
Vespa Rally 180 BMW R1150R Suzuki Burgman 400
@ronin avatar
You will love the Zippys! I rode in the rain for the first time with the new tires and wow, in the wet they grip as good as the stock tires did... in the dry. Don't forget your Dyna-beads if you have any balancing issues. They are awesome!
'08 Piaggio Fly 150
'08 Piaggio Fly 150
Wayne B
VERY good idea.
'08 Piaggio Fly 150
'08 Piaggio Fly 150
I took one short ride and WOW! What a difference the Zippy's make! The ride is much more stable, especially in the turns.
I notice that the shop used square shaped weights on each tire, so I assume they are balanced. Time will tell.
Thanks for the input!
-- Laura
[ Time: 0.0138s ][ Queries: 3 (0.0045s) ][ live ][ 343 ][ ThingOne ]
