Honda Foresight 250
Honda Foresight 250
The time has come.
I'm especially miffed now since I've just spent a bit of time typing a load out only to lose it all by testing the link. Headache emoticon
So now for the short version: I'm changing my rear tyre. I'm going to take the wheel to a garage to get the tyre and get them to put it on the rim. My exhaust is rather rusty so I'll give this a rub down and repaint while it's off.
(Struggling to think now why I didn't keep it so concise the first time - obviously not my style.)
I came across this step by step guide for the process and thought it might come in handy for others on here - apologies if this has been posted before but I've done a search and don't recall seeing it.
Anyway, I also wanted to check what kind of lubricant this "wheel grease" the chap mentions is. Is this a generic type of grease? Does it keep well or does it have a shelf life? Aside from the tools and the "cotter" pin (which I assume I can pick up from Sutton's) can anyone advise of any other essentials to have on hand when tackling the wheel?
Opinions will be appreciated (within reason ).
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Just use normal high temp grease for bearings etc that most people have in there workshop .
While the wheel is off I normaly change the gear oil as it's then a 10 minute job
Plus copper grease all bolts as you put them back .
@harvey avatar
@harvey avatar
He called it 'axle grease' it's a bit of a generic term. Here's the burb on Shell's axle grease (Rotella HD grease) "general lubrication of wheel bearings, axles, ball joints, universal joints, power take-offs, king pins, bushings, and disc brakes."
You may think of using anti-seize on the exhaust nuts:
"COPPER ANTI-SEIZE LUBRICANT
Exclusive formula suspends copper and graphite in a high quality grease. Protects metal parts from rust, corrosion, galling, and seizing at temperatures to 1800°F (982°C)."
It will help next time you have to do a tire change.
I noticed that he seems to be using a torque wrench to undo his axle nut. I bought a 2 foot 1/2" drive breaker bar for that kind of thing (or over tightened oil plugs, & car lug nuts).
Regards
Harvey
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
That's actually a really nice simple step by step write-up....
[ Time: 0.0119s ][ Queries: 3 (0.0033s) ][ live ][ 343 ][ ThingOne ]
