Posts: 5109 Location: west aus |
yes. done it with all manner of oils including 2t...usually with whatever is in reach, with no discernible difference. just dip your thumb & pointer finger in it and run the cable through, don't go crazy trying to pour it in the outer or anything.
Posts: 1236 Location: Roseville, MI |
just go to a bike (bicycle) store and buy a thing of molybdenum disulfide cable lube AND the skinny needly thing that goes on the bottle.
⚠️ Last edited by smallstate on UTC; edited 1 time
thanks jedi
i was going to go crazy and funnel it in with a plastic bag and a elastic band |
2 stroke oil will break down. moly will not and graphite will not. but graphite is fucking dirty shit.
oh that sounds better smallstate
i might just wait till ive got some money and buy some 3in1 light oil thanks for the suggestions guys |
1974 Vespa 90, 09 Buddy 70cc, "lil bastard"
Posts: 93 Location: raleigh,nc |
correct term for "cable lubeing"
,, after working on ships 20+ years and seeing 1000`s of miles of large cable lubed,, the term is called "slushing" and often done with a paintbrush ( depending on the size of cable_or_ a cut down mop head. So i take a
cut down art brush and use that. or i`ve pulled the cabel thru a rag in cable grease? hmm wonder if slick-uid works? |
RIP
Re: cable lube
joshzingzing wrote: is it ok to use two stroke oil to lube the cables? The best lube for your cables is Tri-Flow lubricant. You can buy it at any hardware store. I have used it for years and it comes with a nozzle ideal for accessing lube to the inner without removal. Cheers |
I used two-stroke oil on the throttle cable of my lambretta a few weeks back. I was miles from home and I figured it was better than nothing. The last cable lasted 10 years, even if I only get half as much from this one I'll be chuffed.
At home I fill the outer with tryflow and then use grease on the inner. |
Sir Frets-A-Lot
Posts: 11197 Location: Bee eff eee. |
oopsclunkthud wrote: At home I fill the outer with tryflow and then use grease on the inner. (and I wasn't!) makes me wonder why I bought regular cable lube... hadn't even thought about tri-flow. Thanks for reminding me. |
No Scooter no more...
Posts: 1611 Location: Brighton, England |
+1 on the two stroke oil
I never use anything else, its there, its free (kind of) and its quick (stick the cable in the auto lube tank run your fingers over it and stick in in the outer...piece of piss) how often are you changing cables?? if i bought some fancy shmancy lubby shit, it would sit on the cupboard under the sink for years and i'd probably end up forgetting i bought it and I would use 2T oil anyway cos cables snap mostly when i'm out and i wouldn't have the fancy shmancy lubby shit with me. |
Posts: 5833 Location: Indo |
