1985 MotoVespa PK125S
Hi
I just bought a Et4, and it was dropped by a previous owner.. there is the scratches on the side above the engine, and on the right side front, there is some dents and ripples.
Is that front piece changeable?
(it wouldnt load my picture, so if anyone needs to see it, give me your email)
Honda Foresight 250
Honda Foresight 250
If it's the piece I'm thinking of, then no - it's part of the frame. I don't think this means nothing can be done about dents there, right enough. I seem to remember someone posting some pictures of an awesome job being done getting dents sorted out: I think it might have been genie. I suppose it depends on the seriousness of the dents.
Far too much usage of the word "dents" in this response.
ok, they arnt very serious, its just annoying looking. and then the plastic on the back side right under the handle bars is broke.. and the trim is coming away from the metals..
thanks
@xmanhoe avatar
@xmanhoe avatar
DENTS!!
Here was my 2007 372miles from new £350 !! with dents!! 15min with a hammer and dolly and its ready for filler
well nearly
well nearly
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
yeah that was me - i had a nasty dent in the front of mine caused by a car changing lanes into me. if it's just minor damage it's really simple to sort out though not cheap if you want to get it done properly.
your picture probably wouldn't load because it was too big - have you tried resizing it? the limit is 800x800 pixels.
My Dents
Here is the dents on mine, how hard is this to fix? How much you guys think it would cost to have someone do it properly? I don't have any experience in doing body work, so I don't really trust myself.. haha
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
that's relatively minor and easily fixed. the dents will have to be hammered out and filled, which means taking off the glovebox and indicators, the trim will need replacing (if you're fussy - if you're not it can probably be re-fitted), the glovebox will need to be repaired (plastic-welded) or replaced if you're really fussy, and the front legshield will need a respray. i am no expert in repair estimates but based on what some mates have paid recently for getting work done on their scooters, i'd venture a guess of £3-400 or so, if you get it done at a bodyshop. it may be cheaper outside london.
there are people out there who do bodywork on a cottage industry basis; some of them are very highly skilled and will do work that is comparable to - if not better than - a bodyshop, at a really competitive price. if you're going to go that route make sure you do your homework, go with somebody who has been recommended to you, and make sure you see some of their work before you hand over your scooter.
@got_mine avatar
@got_mine avatar
Fixable but....
Looking at the floorboard where it meets the frame and the mis-alignment of the horncast.... When you fix the dents have the alignment checked also.
It looks like your rake angle has changed...
I speak from experience on this one...
@xmanhoe avatar
@xmanhoe avatar
EASY
This is easy fixed ,i too have no experience of bodywork but i was able to do mine and as you can see it was worse than yours lol.1st take off glovebox, the cracks are easy to fix with superglue get the one that has an activator pen with as it will bond plastics.Then just put a hammer on outside and hit with a hammer on the inside .You do not want to beat the dent out too much as the bodyfiller will take this up. if you lived closer i would do it for you
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
got mine wrote:
Fixable but....
me too Crying or Very sad emoticon ... the rake angle on one side of mine is very slightly 'off', which means the whole legshield is very slightly twisted to the right (the side i was hit on). the bloke who hammered out my dents didn't have a jig (which is the only way to sort out the rake problem) so i've been riding around with a slightly 'off' front end since january. it doesn't affect handling (unless i take my hands off the bars, and i can feel it pulling slightly to the right) so i'm leaving it as-is until i get enough money together to take it into a body shop with a jig.
@xmanhoe avatar
@xmanhoe avatar
JIG
As long as the main centre rib, where you handlebars attach, was not damaged you should be ok.Mine had more damage an is ok .It you check you tube there is video of how to remove dents with hair dryer and co!! tryed it on my car and it worked!!! www.youtube.com/watch?v=x0bJd2HPc_k
i guess 300-400 isnt that bad...i feel like if i tried to do it, i would probably make it worse...
got mine wrote:
Fixable but....
i have no idea what a rake angle is. im new to scooters... can you explain? is alignment something that is tough to have fixed?
Re: EASY
yeah yours was pretty bad, but it does look quite nice now! nice of you to offer to do it for me! haha
Re: JIG
Well hopefully mine wont be bad! haha i watched that vide, impressive!
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
Mr Sean wrote:
got mine wrote:
Fixable but....
here's a useful basic explanation of rake angle:
http://en.wikipedia.org/wiki/Bicycle_and_motorcycle_geometry
if your scooter takes a hit on the front end, it can change the rake angle - in other words it can push the handlebars closer to to the seat. a really serious collision will sometimes push the handlebars so far back that they touch the seat, in which case the scooter is probably totalled - you can't pull it back into shape without substantially weakening the frame. minor collisions can also change the rake angle on one or both sides, but it's possible to pull the frame back into shape by putting the scooter into a jig. again i'm by no means an expert but based on the damage to my own scooter - which is repairable - you're probably fine, a good body specialist with a jig will be able to get it back into shape for you.
thanks!
genie wrote:
got mine wrote:
Fixable but....
well mine doesnt pull or anything, if i take my hands off the bars it just goes straight...
LX125 x 2
LX125 x 2
If I take my hands off the bars, I'm dead.
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
Mr Sean wrote:
genie wrote:
got mine wrote:
Fixable but....
that's what it should do. it sounds like you're fine.
@xmanhoe avatar
@xmanhoe avatar
RE DENTS
Got time to do a bit more today, not long until paint time
wee drop of "LUCY" on it
wee rub down and prime just a few low spots to do
[ Time: 0.0087s ][ Queries: 4 (0.0024s) ][ live ][ 339 ][ ThingOne ]
