HELP
My 2004 ET4 stopped working tonight and all the lights are intermittently not working.
Here's the background, I don't know what is relevant, so I'm including everything, so please excuse the wordiness.
About 4 weeks ago, we had both tires replaced.
About 2 weeks ago, we heard a rattling noise like cans were being pulled behind the scooter. The noise quickly disappeared.
About 1 week ago, we put in too much gas and it came shooting out of the tank. Once the gas settled, it was about 4 inches from the top.
The scooter has been working fine other than any problems previously mentioned.
We have about 4,200 miles on it and have been using it daily for the past month.
Tonight, I used it to go to the gym and the store. Immediately after starting it at the store, I heard a slight clunk, the engine turned off, and all the lights went out ( including the dash, headlight, and tail light.)
I did not smell anything.
I was able to kick start it and drive it home. It started on the second kick (I've never kick started it before, so I really didn't know what I was doing).
Once home, I started testing it and here are the results of my "testing".
Without the key, the red light on the dash was blinking in about one second increments.
I put the key in and turned it to the right. The lights on the dash slowly appeared.
I pulled the left brake, and all the lights went out. The Vespa did not try to start. No noise was made. The lights took about 3 seconds to return. I was able to repeat this three times. The fourth time I pulled the brake, the lights stayed on.
I then pulled the left brake and pressed the black start button...and the lights went out. The Vespa did not try to start. No noise was made. The lights stayed out for a while (from 3 - 30 seconds) then turned on. I was able to repeat this procedure ten times.
I then turned the red kill switch off (meaning the Vespa should not start), and when I pulled the brake and pressed the start button, the lights stayed on. I was able to repeat this four times. Each time the lights stayed on and the Vespa did not try to start (as expected, since the kill switch was off).
I then turned the red kill switch on (meaning the vespa should be able to start), and the problems resumed.
I was able to repeat these problems with the master key.
Any idea what is causing this problem?
Brian
