I like my J. Costa fine but I've noticed that it improves the revs rapidly and there is this little spot where the clutch lags behind it. So my question is, does the J. Costa function better with a new clutch and what do you suggest?
Oddly enough, I had corresponded with Paul at Union Material about the Dr Pulley rollers and clutch and just 2 days ago he emailed me (after quite a while) to see if I still was interested in his stuff. I told him I had gone with the J. Costa, and he said the following:
It's ok, you can go with J Costa's variator.
Following opinion is just for your reference only.
The function of anyone's variator is to tune and make sure the gear shift proceed at the engine's power peak.
But the function of clutch is to transmit the power (ie. comes from the variator) to the ground.
That means no matter how good is the VARIATOR ,you still need a GOOD clutch to get the most power to the ground.
If the grasp force of clutch is too weak ( ie. the transmission efficiency of clutch is poor ),you just waste the power into friction heat ( ie. clutch bell becomes BLUE ).
Regards,
Paul Wu
I'd love to hear some opinions, especially yours, jimc since you are big on the J Costa - but everyone else's as well.
