@big_foot avatar
Scooterless at the moment
@big_foot avatar
My P200E keeps losing the low beam headlight,
I've now been forced to use the high beam during the daytime.
(Can't ride at night for obvious reasons)
What is causing the low beam to keep blowing,
This is the second time in 3 weeks.
The fuse is a 30 amp fuse
(Not sure if that is the problem)
@gravyhand avatar
P200E
@gravyhand avatar
P200E
Which kind of headlight do you have: sealed beam or the bayonet style?
@big_foot avatar
@big_foot avatar
I think it is the bulb type replaceable kind,
The filament is not lighting in low beam just high beam
@andrea avatar
Sponsor
DL200, TV2, Vega, Lui, GTS
Sponsor
@andrea avatar
Check the low beam circuit from the handlebar switch to the bulb. Sounds like you have short there somewhere. The low beam circuit is different than the high beam circuit,
BTW, the fuse doesn't have anything to do with your headlight on your bike, but 30 amp is way too high. It should be an 8 amp.
Andrea
Do Vespas have a voltage regulator and/or diodes of some kind?
@wasplover avatar
2016 Vespa Sprint 150
@wasplover avatar
I had the same problem with my Piaggio Zip 50 before. The replacement bulb would blow (but only the low-beam) just by riding round the block. It turned out to be a faulty voltage regulator.
@big_foot avatar
@big_foot avatar
Andrea
Why would they put a 30 amp fuse in there?
I'll ask them when I take it in tomorrow after work to get it fixed.
Found the electrical diagram here.
I just hope it's safe to run for one more day with the 30 amp fuse in there,
I can't get to a store to get a lower 8 amp one until after work
⚠️ Last edited by Big Foot on UTC; edited 1 time
@big_foot avatar
@big_foot avatar
Couldn't find any 8 amp fuses,
Just 7.5 amp fuses.
Hope it is okay to put that in.
@big_foot avatar
@big_foot avatar
I'll have them check that out tomorrow when I take it in after work,
I've booked an appointment for friday evening.
Thanks for the tip.
[ Time: 0.0095s ][ Queries: 3 (0.0018s) ][ live ][ 339 ][ ThingOne ]
