@1969lambretta avatar
gts 125 super
gts 125 super
i really need some help i have just completed a belt and roller change on my gts125 and there i something wrong! i wanted to change the rollers as they were a bit noisey, so after getting all the advice i could even off your tec' corner i was confident that i could tackle the job myself. i ordered the parts and as soon as they were delivered i set to work. i stripped everything down the belt looked fine but decided to change it while it was in bits. every item i took off was layed out on a board and marked eg. where it was from and which way round etc.... so no mistakes. all seemed fine and it. went back together like a dream, everything was finished tools put away, then i started it up, now the noise is ten times worse Crying or Very sad emoticon what have i done wrong??? so i stripped everything down again thinking i had put something on backwards. rebuilt it again still the same..... now i was getting worried so i decided to try again but rebuiding it using the old parts, thinking the new parts may be wrong but its still the same. i am at a loss of what to do now so is there anyone that can please help me out. thanks dean.....
@drewteague avatar
@drewteague avatar
Hmm.. did you make sure to compress the clutch pulley spring so that the belt could rest properly in the variator pulley? This is probably the most common error here.
gts 125 super
gts 125 super
got me thinking
to what depth does the belt need to be between the pullies?
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
Re: got me thinking
Right in. There are plenty of pics in the wiki...
https://modernvespa.com/forum/wiki-gts-300-jcosta-installation
@bobovespa avatar
21 75th Anniv. Primavera, 10 GTS Super 300, 64 Allstate, 61 VNB, 61 GL, 61 Lammy LI 125 Mahi Shriner, 57 Lammy LD125
Location: Baltimore-Washington-Asbury Park at the Jersey Shore
@bobovespa avatar
It's not hard to put the rollers in backward. Would that make the noise?
gts 125 super
gts 125 super
they were put back the same way they came out i made certain of that.
[ Time: 0.0089s ][ Queries: 3 (0.0016s) ][ live ][ 339 ][ ThingOne ]
