@mike_m avatar
1986 Vespa PX 125E, Pinasco 177
@mike_m avatar
I've got a couple of small dents on each cowl that I would like to remove myself. Whats the best way of doing this? Just bang it out from the opposite side?
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
I used a hammer and dolly to get them close.
Then I used this thing that was like a cheesegrater, but for metal. I could bend it to the shape of the cowl curve. That took out any peaks from hammering. Sorry, I don't know the name of this tool.
From there, I used a minute amount of body filler and sanded it smooth and primered.
1997 T5 Classic
1997 T5 Classic
in the UK i bought one of these sets and it served me well on my classic mini for all dints. I assume you can get something similar over your end
http://www.machinemart.co.uk/shop/product/details/cbp7a-panel-beating-set/path/bodywork-tools
@jeremy_w avatar
@jeremy_w avatar
That looks like a nice hammer and dolly set.
Here's a pic that is close to the file I was using. This one seems to stay straight. The one I used could be bent to the shape you were filing.
@mike_m avatar
@mike_m avatar
The dents are smal enought that I may be able to gently bang them out from the opposite side. Any thoughts on the suciton cup device?
@brett_k avatar
2005 Vespa PX150, 1976 serveta jet 200
@brett_k avatar
a friend did it for me, he used a soft hammer and a piece of wood, worked great. It was a fair size dent too.
@veloce75 avatar
not-so-normal
@veloce75 avatar
not-so-normal
and I did it on my mudguard...
Rally 200, P2, 150 Soop, Cosa, ET2
Bodyfile?
Also great for ripping thru body filler before it's properly set to get a rough shape to the filler/repair.
Re: Cowl dent removal
You don't want to do that, you'll likely overstretch the metal. Invest in a hammer and dolly set. You can get away with a cheap set from ebay and the likes if you only plan on occasional use, just don't expect them to last or expect the same quality as Sykes Pickavant sets etc.
Practically impossible to explain in writing how to do this but the basic premise is to let the dolly do the work in pushing out the dents from behind while gently hammering 'on and off' the dolly working around the ding. Takes time and practice and a keen eye/hand to get right so probably better practising a little with some scrap metal.
[ Time: 0.0126s ][ Queries: 4 (0.0055s) ][ live ][ 343 ][ ThingOne ]
