Have any of you had installed the below?
1. The Prima (Faco) side crash bar is not as robust as the Piaggio original and is a single bar. Would this hold up as well as #2? $119.00
2. The Prima (Faco)..almost generic crash bar...wondering if the additinoal frame around reflector adds any support. $149.99
BTW...I did remove my reflectors and have installed cover caps.
3. The Prima (Faco) front rack...does this really work well? I would use it to support a 20 lb. bag of cat food and possibly tie down a small crate box to transport stuff...just wondering if the drop down shelf is really that functional and can handle the weight. Is it worth it and does it affect your ride (seems like the added weight forward may not be a good idea)? I got ROK straps and I could secure same on seat behind me. $119.00
Would appreciate your comments.
