While the MP3/250 and /400 have a number of windscreen choices, the 500 is thus far rather limited. I tried the GIVI medium (Figure 1) but was uniformly unsatisfied; first, because its height was inadequate, and secondly, because of the wind coming around it. I installed a Laminar Lip across the top, which eliminated wind across the top, but not the sides. The GIVI is, IMHO, designed more for looks than wind protection; its narrow profile means wind pours around both sides and collapses directly in front of me, resulting in terrible buffeting. I have read rave reviews of GIVI sheilds on this forum, some of which claim that the GIVI blocks too MUCH wind. Perhaps that's true of the 250/400 models, or maybe the reviewers weren't out on the highway - anything over 60mph and I could not help but be violently buffeted (I will say that with the LIP, riding up to 55mph was quite comfortable). In any event, let's just say that I could not get it to work for me.
Also, I could only find the GIVI in medium smoke, and the LIP was really dark, Foster Grant dark. But I'd put up with it if they kept the wind off. I even considered extra LIPs (the company makes vertical "ears") but they'd never fit the GIVI screen due to excessive curve.
I had a Rifle shield from my Honda Shadow available (Fig. 2), and decided to give it a try. Here's how I did it.
The first problem is that the only lower connection point on the MP3 is dead center. The cruiser windshield has, as you can see, a great big headlight cutout hole right where it needs to connect to the MP3's fairing. As some of you know, I tried to find anybody who sells just a blank windscreen (i.e. a big "egg" that hasn't had the cutout for a motorcycle headlight made yet). The only company I could find that sells them - and I tried a lot, including most if not all of the customer plexiglas web sites - was a Chinese wholesaler of plexiglas blanks. But I had to order a minimum of 10,000 of them. So, how to use the existing Rifle?
Looking at Fig. 2, you'll see that the headlight cutout has screws attaching the vertical bands on either side. So, I removed all the hardware, and remounted the horizontal strips (one in front, one behind the plexiglas) along the bottom, bisecting the headlight cutout. This meant I had to drill an extra pair of holes in the bottom outboard corners to pass the outside screws through.
The rest of the holes I plugged with 3/8" plastic plugs. As it turned out, they rattle quite a bit at speed so I glued them in place with loctite (I would have prefered rubber plugs but couldn't find any).
I then drilled two new holes to transfer the GIVI bolt flanges and grommets to, then bent the GIVI arms ("stalks") to match. That turned out to be quite complicated; I did not anticipate how difficult it would be to bend them both the exact same amount and without damaging them. Moreover, because I had already drilled the holes in the windshield for them to match up with, I had to bend the arms just the right amount to match the holes, which meant bending them while mounted on the trike. This is extremely difficult, both to get them bent equally and more importantly not to damage anything (like ripping out the speed nuts at their base). I used a deep-socket wrench on the top and a pipe wrench on the bottom of the arm, which then imparted deep scratches even though I wrapped everything with plumbing tape (in the pictures below, they've been sanded down and repainted) The right way to do this, in hindsight, is to remove them, mount them in a vise, bend them with a pipe just slightly larger than the arm OD, and make a paper cutout of the angle of one to use as a guide to match the second one to...and THEN drill the holes in the windshield to match!
The reason all this bending was needed is because a cruiser windshield has a relatively mild rake, while the GIVI is angled very sharply (which I guess in Italy means, very stylish). Ideally the windshield should sit at about 10-15 degrees from vertical. This means that the windshield will no longer be parallel to the GIVI bracket hidden under the front fairing, and so the mounting screw will not line up (see Fig. 4). The solution to this was to take that square "U" bracket that GIVI provides to mount under the fairing (which connects to a frame screw on either side) and bend it so that it was now facing more horizontal (note that the external GIVI bracket, that takes the one through hole and branches out to two small arms that attach to the GIVI shield on either side of the logo, is not used at all in this installation). That fixed the "parallel" issue, but it introduced a new problem of geometry, in that the screw hole of the hidden GIVI bracket is now physically lower than the through hole in the fairing. I had to drill another hole slightly below the original, as shown in Fig. 5. Now the screw - which is a considerably longer 6mm stainless button head than the original GIVI, since there's lots more things for it to pass through - lines up perfectly. I put rubber washers between the front and back horizontal straps to keep them spaced, and behind to absorb vibration.
By now, I had removed and remounted the various screens so many times that the internal threads of the GIVI "T" brackets - which are only plastic - had started to strip. This is frankly a weak and poorly engineered aspect of the GIVI screen and hardware. I drilled a hole clear through the "stalks" and threaded them 10-24, going slowly, using lots of oil, and backing the tap out often to clean out metal filings. I was hesitant to use 10-24, a thin screw, but was even more afraid of drilling a substantial screw hole like 6mm or 1/4-20 and missing dead center and ending with half-a-hole. The 10-24 gave me a little leeway on drilling accuracy and, it turned out, is far more than strong enough for the applicaiton.
The result is that the mounting screws (2.25" x 10-24 stainless) now screw through the windshield via the GIVI grommets and then directly into the arms themselves. I then backed them with stainless steel nylocks to make sure they never loosen; see Fig. 6.
I was ready for a test drive!
⚠️ Last edited by rjeffb on UTC; edited 15 times
