@mrscience2008 avatar
2009 BV 250
2009 BV 250
Just ordered a headlight modulator, now looking for a horn. Amazon lists two horns: Stebel Compact Airhorn ($35) which uses the existing horn button and Stebel Nautilus Compact Motorcycle Airhorn ($37) which has the 30 amp relay. Motorsports Scooters also has a Stebel Nautilus Airhorn for $55. The two horns from Amazon are both rated at 139 dB. Which horn should I get for a BV 250? Is the Stebel Nautilus horn from Amazon the same as the one from Motorsports Scooters? Amazon also offers a wiring kit for the second Stebel, is it worth it?
Esme Partly Kitted ET4.
yes a stebel is worth it.. I've had a couple of people come in to our workshop wanting this installed, suddenly there has been a rise of stebel horns around fulham and chelsea lol. (West London) I've ordered mine in today and should be with me on mondat to install into my ET4 woohhooo..
@scooter_west avatar
Sponsor
Sponsor
The regular Stebel 136db is an easier fit and an easier install. The Nautilus is much louder, but you have to supply your own wiring and connectors.
@dfndr avatar
MP 3 250
@dfndr avatar
MP 3 250
How do they compare?
How many deciblels is the stock horn on LX or S 150? Is the Stebel electric horn loud enough to make the effort worth it?
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
I bought the TM80 here for $18.95 for my FJR and it works great. I also bought the Nautilus Compact for $39.95 for the GTS. LINK
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Yup, it is Stebel fever these days. The Nautilus Compact for motorcycles was a tight fit but the Wiki tutorial was brilliant and she went in no worries.
The sound output is feakin' amaaaaaaaaazing!
@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
I love my Stebel Nautilus! Its an easy fit on the LX, but I am not sure about the BV250
@trowel_and_cuffs avatar
The Stebel are excellent! I have the compact one on mine and man it "blows"! hhahahaha! Clown emoticon
@benito avatar
@benito avatar
A friend of mine has a Stebel airhorn in her BV 250, so it can be done. It was done by the dealership so I don't know where they placed it and how difficult it was though.
GTV 250
GTV 250
I bought the Nautilus but didn't fancy all the relay wiring, so I took it back for the Magnum.
I think I might take that one back too now, and go for the relay one when I have some time to fit it properly.
@tb avatar
@tb avatar
Stebel Nautilus / Wolo Bad Boy (Checkers). Wolo seems to be a generic to the Stebel...cost differential...none ~ same.
Relay wiring and inline 20 amp fuse a bit of a hassle but the thought of knowing that you've really got what you need to be is comforting.
@mimsta avatar
GT200
@mimsta avatar
GT200
I'm thinking of upgrading my horn after a near miss the other day. I was going at about 80k's down Dandenong Road the other night when a dufus in a white station wagon did a u turn in front of me. To complicate matters when the driver did actually see me she hit the brakes! Lucky I was able to do a quick countersteering thingy and swerved around her.
However, the pathetic toot-toot of my horn after the even just added insult to injury! I felt like an angry pixie!
I'm not really after an air horn that plays "La Cukooracho" (sic) so one of these Steble suckers should do nicely!
@pdxscoot avatar
BV500 - GTS250
@pdxscoot avatar
BV500 - GTS250
I have a Nautilus on my BV500. It fits right in the front near where the stock horn is.
The link to instructions on how it's done on a BV500 is at:
Stebel Nautilus installation on BV 500
I know the 250 has a different front end, but there are similarities and this posting may prove helpful...especially when it comes to wiring it all up.
-Arjen
2009 BV 250
2009 BV 250
Stebel
-Arjen
Thanks Arjen. I already had that page bookmarked. I ordered a switch today--I'm going to try to keep the original horn along with the Stebel. I don't know how long it will take to get the switch, but I am in no hurry. I also ordered a headlight modulator, which should arrive in a couple of days. I'll install that first.
You made a bracket to install your Stebel? Can you tell me how you did that? Thanks.
@pdxscoot avatar
BV500 - GTS250
@pdxscoot avatar
BV500 - GTS250
Yes I made a bracket. Sorry that I didn't take any pictures. I made it with a piece of 1" wide x 3/32" steel strapping (available at Home Depot..I used a wood connector - made by the guys that make joist hangers - that way it was galvanized). It worked better than the wire tie approach used in the MV posting I referenced. I did not have to cut the tab off the horn. I do remember that I mounted it upside down with the horn oriented down towards the front.
[ Time: 0.0113s ][ Queries: 5 (0.0025s) ][ live ][ 343 ][ ThingOne ]
