@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
I just completed installation of the Stebel Nautilus on my LX.
I bought the horn plus the installation kit, and printed out the wiki references to this project. I will say that everyone's installation, from an LX to a GT, were well written and very helpful.
I followed the guides, while verifying the wiki instructions with those in the kit.
I am glad I bought the kit, for no other reason than a comprehensive diagram and instructions that are different from our wiki. The first thing that jumped out at me was that the kit instructions said to place the relay no more than 8" from the battery. Of course, all of our reported installations mounted the relay behind the horncast. The kit was good and I'm glad I bought it, except I still had to buy #14 red wire because the 3' in the kit isn't enough for a scooter. Another issue was the ring terminal was too large for the Vespa battery terminal, so I had to buy a smaller one...on Saturday in a small town... all I could find was a Hootchie Mama of a big ass plastic assortment of enough connectors to last a lifetime. So, that one ring terminal cost me $15.29!
OK, the nitty gritty of my post, and I want to apologize for not taking pictures other than one when it was all buttoned up. I didn't even think of it until I was almost finished and didn't want to start taking stuff apart just for a photo op. My bad.
I have read just about every entry covering Stebel installations and one thing always bothered me and that was the method of mounting. Some used tie-wraps and others used hose clamps. Neither one appealed to me.
Once I had everything apart, I looked and looked for a way/place to mount the horn that would be a clean installation. The LX cavity is fairly snug. I can't imagine how it is in the GT/GTS.
Following the wiki, I removed the old horn. It was attached to a formed bracket that nested beneath a welded platform. On top of that is a zinc plated bracket that holds a fused terminal gizmo with a few wires coming out of it.
I noticed one thing right away; the welded platform has an almost vertical surface underneath it. On my scooter, there is some kind of heat sink mounted on it with two 5 mm screws. Right below the heat sink was an area that looked suitable to mount the horn. It even had a 5mm tapped hole in it, right in the center.
Looking at the Stebel horn, the back of it has a mounting lug that has an elongated half hole, that accepts a special 8mm square head bolt and nut, both of which come with the horn.
Looking at the hole in the vertical platform, I considered drilling and tapping it to accept the Stebel mounting bolt, but realized it wouldn't have enough room to swing the horn around to tighten it.
So, the answer was to drill the hole out to clear an 8mm bolt. I was able to use a 5/16" drill, wiggled slightly to "Chicago" the hole. A better choice would have been a letter "O" drill, which I didn't have.
Once drilled through, (be careful because the steering column is not too far behind it) I used a small mill file across the back surface to remove the burr. I accessed it through the area vacated by the previously removed glove box. The throttle side of the scooter gave the best access. It took a bit of time to get the burrs off, but it was worth it.
I assembled the bolt to the horn and inserted it through the hole. The bolt was a bit too long and would hit the steering column before the nut was tight. I took the bolt and threaded the nut on, then I cut about the thickness of a flat washer off the threaded end of the bolt. then I removed the nut, which chased the threads as it was unscrewed.
I found the best way to mount the horn was to put the bolt through the hole in the frame, screw it into the nut which was being held on the back of the mounting pad, a couple of turns just to hold it. Then, slide the horn mounting lug down over the bolt head. The head is square and thin and fits into a groove under the lug. That prevents it from turning while you tighten the nut. Once in place, use a small end wrench to tighten the nut. A used 1/2" works well, again, the throttle side gives the best working space.
The horn is a perfect fit and has a bit of room all around. It even cleared the heat sink which was then replaced. One thing I found out, identify the + and - terminals on the horn and slip on the wires and connectors before mounting. I left them long enough to connect later in the installation. The + goes to the relay and the - goes to ground. I used the mounting screw that held the old horn bracket, which now is used to hold the relay. I took the eared bushing and washer off the old horn and left the rubber grommet in place. A 5mm screw and washer inserted from the back, followed by another washer in front, then the relay and finally the nut snugged up and you are looking good. Again, I found it easier to connect the wires to the relay before mounting it. That way, you can see what you are doing.
The rest of the installation is pretty much wiki to the letter.
All in all, I am very satisfied with how it turned out. It absolutely looks like a factory job. BTW, I even snapped the little plastic snorkel on the intake of the horn. You know, that funny looking thing that fell out of the package when you opened it?
I don't know if all LX's have that platform. If so, strange that nobody ever attempted to use it. In fact, the pix I have seen of the horn area on other LX's don't show the heat sink.
OK, there you have it. Sorry about the pix, but if you review the wiki and look at your own scooter and the horn, you ought to be able to figure it out.
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Thanks for the new info on Stebel kits and installs. Every bit helps for those who are to follow.
Any idea (technically/electronically) why the relay should be closer to the battery?
Cheers
@silver_streak avatar
Cheers
Normally, on a high-current circuit one keeps the total wire length as short as possible to minimize voltage drop in the wire (thus more available for the device), but in this case the total wire length is dictated by the horn location. Electrically, it makes no difference where along the circuit the relay is located.
'Tis a puzzlement.
@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
Nice write up and welcome to the Nautilus club.
@mateo avatar
2008 Vespa LX 125
@mateo avatar
2008 Vespa LX 125
an option #3?
Tomorrow morning I go to a local vehicle electrician to mount the same Stebel horn in my LX125. I used the tutorials from this sight to learn how to take the whole thing apart. Yesterday I spent the afternoon taking the whole scoot apart (the parts for the horn installation) and put it back together. Here it is assumed you hang out with the mechanic, electrician as he works on it. I will take the LX apart (and put it together when he is done) and then he will do the installation of the horn, BUT I am going to have him mount it and leave the old one. The LX125 in Spain has a dumby switch (plastic cover) over a hole that could be used for an ON/OFF light switch, but isn't (right above the starter). He is going to modify that opening for a switch for the Stebel and the regular horn switch for the original beep beep.
I will let you know how it goes and yes, I will try to take my camera with me.
The only reason I can come up with is general safety: if you keep the length of wire from the battery to the relay short, it minimizes the chances for that segment (which is always "live") to chafe against something. A longer wire, snaking through the bodywork, will have more chances to fray and short.
A good solid battery-connected wire will weld itself to the frame if it makes contact.
@benito avatar
@benito avatar
Re: an option #3?
I like your idea, that way you can have the option of a friendly meep meep, or an angry blare of the Stebel airhorn. 8)
@nightwing avatar
Contributor
Contributor
@nightwing avatar
Re: an option #3?
I considered that, and was even contemplating a selector switch that would allow toggling back and forth between the Stebel and the standard horn, using the same horn button. I decided to just use the Stebel. Sort of like having a blow-up doll and a real girlfriend. As long as the GF is working, no need for the dolly.
@rogthemod avatar
Vespa 125 LX and Lambretta SX 200
@rogthemod avatar
I have fitted one to my LX125 and I found the installation much easier with the inside legshield box removed. I too used the existing horn mounting bracket but with the rubber cushioned washer removed to get a firmer fit. I had noticed evidence of water penetration in the legshileds where the horn is mounted so I put a cap over the top of the horn, with holes for the two wires, made from the cap of an aerosol can and sealed with mastic. Very waterproof now.
[ Time: 0.0241s ][ Queries: 4 (0.0124s) ][ live ][ 341 ][ ThingOne ]
