2007 GTS 250ie - R.I.P., 2009 GTV 250ie, 2009 Aprilia Mana 850, 2003 Honda Ruckus NPS50
Posts: 198 Location: SF Bay Area |
So after thinking for a couple days about a good way to lock my helmet to my scoot without the entire process being too cumbersome, i decided to go with the rig shown below. I hate top cases (no offense to those that have them, just not my cup of tea), and didn't want to hang the helmet off the seat hook (soft paint, hard helmet, easy to cut). I don't know if this has been done before, but it works for me and I just wanted to share:
Positive
Also makes it easy to run the red cable through my jacket sleeve and drape it over the bike.
shovde wrote: Why do you need both the red cable and the combination lock? Wouldn't the lock be enough? Then again, a simple answer would be that I'm paranoid. I'm willing to spend the extra 10 sec. putting them both on. |
2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
Posts: 1274 Location: Sacramento |
Baart-less
Posts: 4499 Location: 56°58'34.49"N x 111°29'38.40"W |
It would probably be just as easy to use a bicycle U lock over the chin bar and around the rack rails.
Dave |
Chetwynder wrote: It would probably be just as easy to use a bicycle U lock over the chin bar and around the rack rails. Dave |
kriskeyman wrote: shovde wrote: Why do you need both the red cable and the combination lock? Wouldn't the lock be enough? Then again, a simple answer would be that I'm paranoid. I'm willing to spend the extra 10 sec. putting them both on. |
shovde wrote: kriskeyman wrote: shovde wrote: Why do you need both the red cable and the combination lock? Wouldn't the lock be enough? Then again, a simple answer would be that I'm paranoid. I'm willing to spend the extra 10 sec. putting them both on. Though I'm pretty sure this would work with any helmet. |
Posts: 2871 Location: Oregon |
ChillN wrote: I take it the underseat helmet hook doesn't work for this helmet? While the lock and cable solution is certainly effective, it does seem to be overkill to me. I think the cable alone should be enough of a deterrent, but then again I don't know what the neighborhood is like where you have to park. |
ChillN wrote: I take it the underseat helmet hook doesn't work for this helmet? I take it you don't mind using your helmet as a DPR (drunken piss receptacle). |
Posts: 4332 Location: Utah Valley |
RIP
Over two years and over 25K miles of hanging a pricey Arai helmet on the dedicated pin under the seat, with not a single scratch, say it is the better solution.
Your red cable will be more likely to leave scratches on the cowl, I'm afraid. But it affords you more security than the peg solution. However, that strap is hard to cut, with it all being very tight there under the seat edge. Anyway, it is your call, and if it makes you happy, then yours is the best solution for you |
kriskeyman wrote: I take it you don't mind using your helmet as a DPR (drunken piss receptacle). |
bagel wrote: kriskeyman wrote: I take it you don't mind using your helmet as a DPR (drunken piss receptacle). |
