Gilera Fuoco 500 / Vespa ET4 / Aprilia Habana
Down to the last issue on the scoot before it gets sprayed , the Hinges and the plastic bits either side were pretty damaged (the actual plastic hinge was outside the metal holder) , the screw holes are stripped as well as the screw won't tighten , i've cleared it out and tried a couple of things to little success , question is
A. Will this be possible to fix ?
B. Whats the cheapest place to buy the full front glove box in the uk?
And if any one has one for sale in good condition PM me i guess ! Laughing emoticon
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
i'm afraid i don't know the answer to A (though it sounds like it might be 'no'), but as far as getting a replacement is concerned, your best bet is probably a breaker's yard - if you're getting it resprayed anyway it doesn't matter what colour it is.
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
You may be able to fix the stripped screw holes with a 2 part epoxy glue. Do you have Araldite in your country? Pretty tough, verstaile stuff.
I would mix up a small brew and fill the stripped screw holes using a matchstick to 'wiggle' the resin in. Let it set fully for 24 hours before screwing in the self tapping screws. No guarantees but worth a try for a tenner ($10).
Good luck.
boulty has the right idea but I would drill it out first with a small bit before trying to put the screw in.
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Thanks, yeah I neglected that detail. Cheers.
@xmanhoe avatar
@xmanhoe avatar
bout yee
Hi triggs have you tried that metal putty stuff? its like a sausage shape and when you mix it it goes hard most car shops do it it can be drilled and tapped or drop it over to me and i will have a look at it .Lookin forward to seeing your scoot finished cheers Fletch KTF
@ifixjets avatar
01 ET2 - 01 ET4 -- 05 GT200L / 05 PX150 / 23 Triumph Bonneville T-120 Chrome Edition / 23 Triumph Scrambler 900 / 23 Triumph Tiger 1200 GT Explorer / 24 Honda Trail 125
@ifixjets avatar
You could drill through the holes that were stripped, counter sink the out side of the hole, then use a screw and nut to hold it in place. You can paint over the hardware if you have to.
Re: bout yee
I had epoxy putt but was pretty flakey when you tried to screw it in , but i've seen the metal putt your on about on the halfords web site looks promising !
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_199433_langId_-1_categoryId_165691
i'm looking forward to getting it finished !!!
@astromags avatar
@astromags avatar
Good luck.
I did essentially this exact thing with mine and have never had an issue with it since.
[ Time: 0.0127s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
