@luthorhuss avatar
@luthorhuss avatar
Hi folks,
I got another round of pics and a simple mod for ya. First off, here's the 'history' of this mod:
I bought a 37L Shad case with color matched plate. I love it! It looks factory! However, there's not a specific mount for the 500(that I know of) and even if there were, most mounts from Givi, Shad, etc cost over $100 minimum. I originally had made a mount out of bolts and threaded bar from Lowe's, but that was my impatience catching up to me and also because I "needed" the topcase secured the day I got it home Razz emoticon. Oh well, my loss is your gain because I'm gonna try and show some basics on fixing scratches to the powder coated luggage racks and also install a MUCH MUCH better version of my 'el cheapo' DIY rack. This rack is great because basically it creates a raised, sturdy platform that can be drilled out and allow for the install of ANY topcase that has a basic bracket. As for parts, I used Metric bolts that were 6X1.0 X 75(longest they had), with some "fender washers"(the larger ones) and a few metric washers. The risers are Steel spacers that are 3/4 X1.5 inches...I tried 2 inches but didn't leave enough thread contact. I used multiple washers to not only distribute the weight/pressure, but also to add height and fill in the 'gap' between the spacers and bolt head to allow for snug tightening. Trust me, I could sit on this set up and it wouldn't budge. The metal is 1/8 inch thick steel, and believe me, getting the cutting done was the only long,hard part. The drilling went fairly fast, but cutting the steel made me realize how much I need a Rotozip or Die grinder. Enjoy...I hope this saves someone the $80++ bucks it saved me .
The damage done by the scraping/falling apart of last setup. Notice RUST!
Note RUST in crack!  This is NOT from the previous set up!  It's behind rubber washer!
Used brass wire brush to clear off paint/rust
Stripped by brush
Stripped by brush
Next, sanded with 320 grit to smooth transition
Sanded
Sanded
Applied Epoxy paint..great stuff...self priming, weather proof, rust resistant
Prepping cannot be rushed
More blocking
More blocking
After 2 light 'mist coats', did medium coat, sanded with 2000 grit, then last 2 mist coats...
Piece of steel for top rack
Risers/spacers
Risers/spacers
Rack painted and bolted on
Up close of riser/washer setup. Notice how washers 'pinch' steel and also create base on plastic
Four painted black 'pan' head bolts attach bracket to steel. Washers and nuts underneath
Shad bracket came with a nice little "vanity" plate to conceal bolts.  Also why I used pan heads.
All finished and awaiting topcase to snap on.  Rides very sturdy and no shaking.
@sushiman007 avatar
She's an I-talian $$-burning machine
@sushiman007 avatar
very nice!
You finished off beautifully! Clap emoticon
@bohemian avatar
2009 MP3-500 Black
@bohemian avatar
2009 MP3-500 Black
Very nice! I love to see the detail care you took to make it nice and professional looking.
@oldspice avatar
'12 BMW R1200RT
@oldspice avatar
'12 BMW R1200RT
Looking good, luthorhuss!
I'm thinking about doing something similar, but extending some pieces off and down the side of the bike to see if I can't fashion some homemade side case mounts. Still haven't quite figured out how..... must do some tinkering in the garage.
@ramblerdan avatar
2009 MP3 400
@ramblerdan avatar
2009 MP3 400
Nice work, Luthorhuss. Looks very spec.
@luthorhuss avatar
@luthorhuss avatar
Yeah, I also wanna do the same. I'm thinking about ordering these:
http://www.binetto.com/SHAD-Motorcases/SHAD-SH-43-Motorcase-Side-Cases.aspx
They match my top case. When I do, I'm gonna call the Binetto guys and see if they have anything for the 500. If not, I'll likely copy this:
https://modernvespa.com/forum/topic36634?highlight=hard+side+case
(look about 3/4 way down). Lex500 did a great job at making his by drilling out some dogbone risers and then cutting the ends off, creating drill threads and tightening.
My theory is that I'll order th cases, see what brackets they come with and how these affix and then figure something out from there. I think it'll be easier to custom make them once I have them in hand than trying to make a 'universal' one like for the top case.
@luthorhuss avatar
@luthorhuss avatar
More pics with case on...
Here's some extra shots so you can see the side profile and clearance from racks and back of seat as well...
Seat opens and I can reach fingers under if need be too
back
back
side
side
back/rear
back/rear
@sushiman007 avatar
@sushiman007 avatar
Magic!
Work of Art! Clap emoticon
@luthorhuss avatar
@luthorhuss avatar
Re: Magic!
Thanks! . If I get the side cases, I'll put a "How I did this..." up as well. Then I'll just have to rig up lights to both
@sushiman007 avatar
@sushiman007 avatar
Great!
Yeah, and after you've rigged everything up and write about it, I would be the first to nominate it for the Technical Library!
good job luthorhuss. looks real nice. great pics and a good write up.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
you are amazing!
@jerryw avatar
MP3 500, Honda PCX
@jerryw avatar
MP3 500, Honda PCX
Cool job. I'm sure your bike is happy you are its owner.
[ Time: 0.0124s ][ Queries: 4 (0.0045s) ][ live ][ 343 ][ ThingOne ]
