@orange_s150 avatar
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
@orange_s150 avatar
on my s150 i am going to install the euro lights (thank you for the help) but one final question in getting into the horncast. there is a screw in the bottom and one under the badge, how do i remove the badge properly with out breaking it? is there a trick?
this video looks like a good reference but it does not show a trick to remove the badge. http://www.youtube.com/watch?v=Uj-aX7rM_9k
thanks
@der_blechfahrer avatar
When you're facing the badge, look at the right side. There is hole where you can place the flat end of a screwdriver. Use a piece of cloth to protect the paint and lever the badge out.
@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
Removal of the horncast is illustrated in the beginning of this tutorial (located in the Technical section of MV). Make sure that you use a cloth to protect the paint.
LX150: Installing a 12V Power Outlet
@scootaboy avatar
'84 PX150e
@scootaboy avatar
'84 PX150e
..also, make doubly sure all the screws are removed from the headset/lamp housing before tugging to remove. I missed a screw and ended up cracking one of the tabs which are very delicate. See here:
http://www.nycscootering.com/2009/06/11/scooter-newbie-podless/
Best of luck, even with the crack, the mod is awesome.
[ Time: 0.0089s ][ Queries: 3 (0.0027s) ][ live ][ 343 ][ ThingOne ]
