@2011super avatar
2021 GTS 300 Touring
@2011super avatar
Does anyone here have one of these installed on their scooter? I am really thinking about getting one and I wanted some feedback. LINK
102102 - Flash2Pass System for Motorcycles
This is the complete set that consists of the patented transmitter, corresponding receiver, all installation hardware and easy do-it-yourself installation instructions specifically packaged for motorcycles and scooters.
A double flash of your headlight high beam switch opens or closes your garage door
No remote transmitter to get lost or stolen
No batteries to replace
2-wire installation
Weatherproof
Digital rolling code technology for ultimate security
Single receiver works for up to 6 transmitters
Works with virtually any garage door opener since 1982
Vespa S 150 (Red) and Piaggio BV 250 (silver)
I have the system, and love it. Installed the transmitters into two scoots, and the receiver simply wires into and sits on the wall right below my existing receiver. Installation was easy -- came with Posi-tap connectors, which are a great invention (so good that I've stocked up on a few for other purposes). I like the system so well I'm thinking of putting a transmitter on my car. It sits out at night during the summer to make room for kayaks in the garage, and using the Flash2Pass transmitter would ensure that no one can break into the car and also get into the garage.
Anyway, I recommend the system. It's more expensive than hanging a supplemental opener on your keyring or having one in your pocket. On the other hand, I never find myself fumbling for an opener or otherwise distracted as I pull into my driveway and open the garage door.
@mike_bike_kite avatar
GTS250 - GT200 - XJR1300
I don't have one of these but I do have an ordinary up and over garage opener with a simple to use remote. I think it's fantastic - especially in the rain. I put the remote in a waterproof pocket at the front my jacket and just press the jacket as I pull up to my house. If I time it right then I drive in fine without even putting my feet down, if I get it slightly wrong then I tend to smack my head
Sadly the up and over door opener took a bit of a hit earlier this year when a young couple figured that parking next to my rear garage was the perfect spot for making out. I couldn't see their car from inside my garage so just pressed the button to leave - the noise the door made as it slowly worked it's way up the lads BMW was horrendous - and I'm pretty sure it put him off his stroke! Sadly it's somehow damaged the door as well as it only opens 3/4 of the way up now.
The advantage of having a separate remote though is that I can use the remote when I'm out in my old car or bicycling with my boys.
GTS250ie
GTS250ie
Save your money- This garage door opener works better and is much less expensive.
http://www.dumpert.nl/mediabase/494271/d5bfc453/ingebouwde_garage_deur_opener.html
@bagel avatar
@bagel avatar
Sure, the up front costs might be less, but I guarantee you'll end up paying more in the long run...
@dutch avatar
LXV 150 GTV 250
@dutch avatar
LXV 150 GTV 250
I've got a mini opener that I just hang on my key ring. I just reach down and push the button. My driveway's long enough so by the time I get to the door it's open.
@windbreaker avatar
@windbreaker avatar
Re: Flash 2 Pass Motorcycle Garage Door Opener
2-wire installation
Weatherproof
Too simple! Razz emoticon
@2011super avatar
@2011super avatar
Great real world feedback Gin! That is what I was hoping to hear. Thank you.
@pdxscoot avatar
BV500 - GTS250
@pdxscoot avatar
BV500 - GTS250
Unless this one is equipped with a hooker as the actuator...it is the most expensive opener by far.
I get off my scoot.
Open the gate.
Walk forward 20 feet and open the garage doors.
Walk back 20 feet and get on the GT again.
Ride in.
Get off my scoot.
Walk back 20 feet and close the gate.
Come forward 20 feet again and close the garage doors.
~EXHAUSTING~! -I can barely make it up the 5 porch steps into the house after all that..!
(I'm just so out of date with all this mod garage stuff, y'know?) Laughing emoticon
2007GTS, you are welcome. I agree - that's what I most look for on this forum. Real user experience, from real users. Glad my comments are what you were hoping for. Good luck. Post a review if you get the Flash2Pass.
@vespa_hartford avatar
Sponsor
Sponsor
This is what I have to open my garage door. Fits right on the key chain. Can be programmed to open multiple doors.
Cost $40 US
Link: http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=811
@ummgood avatar
2009 BV500
@ummgood avatar
2009 BV500
Chazzlee wrote:
I get off my scoot.
Open the gate.
Ride in.
Get off my scoot.
Your driveway must not be on a 30 degree grade.
@ummgood avatar
2009 BV500
@ummgood avatar
2009 BV500
Cost $40 US
I took something similar. I took it apart. Modified the circuit board to run on 12 volts and installed it with a button on my scoot. Now to open the door I move my thumb and press. The button is in the dud spot on my headset next to the ignition switch.
@crownseven avatar
Scarabeo 500ie
@crownseven avatar
Scarabeo 500ie
I saw this post and immediately ordered a couple for my scoot, and our 2 cars.
My verdict: FANTASTIC PRODUCT! Does just what it says it will, and the install was very easy. I used to have a door opener in the glove box (which is tiny on a beo), not anymore.
Thumbs way up!
[ Time: 0.0137s ][ Queries: 3 (0.0019s) ][ live ][ 343 ][ ThingOne ]
