So, my 2003 et4 was running poorly. Had to baby the throttle up to about twenty mph and then it would take off fine, no problems idling. I decided to remove the carb and clean out the jets. my low jet, idle jet, was clogged. once i put everything back together, and i did so properly, it would start and idle but i could not give it steady throttle. i had to twist the throttle in quick bursts to get it moving then hold it just above idle to maintain the speed. This is where it gets strange to me... I covered the main air intake, and now it accelerates quicker than ever, but once i hit about thirty mph it bogs down and won't speed up at all. If anyone has any ideas as to why this would happen i am all ears.
Cheers
