2006 PX 166 1980 P180X
Anyone got any recommendations of locks or devices that will fit the later disc wearing P range?
Many thanks.
http://www.alarmlocks.com/
I have one of these. I'm pretty sure the cable diameter is thin enough to get through in the front wheel area.
That said, it of course wouldn't be to hard to cut through, but if someone did... the alarm is pretty damn loud.
(Caveat: I live close to the coast where it's pretty humid. The alarm doesn't like humidity at all and gets a little quirky when damp.)
Again, not recommended as a theft preventive, just a possible deterrent.
2 cents...
@macallu avatar
Vespa PK 50 XL
@macallu avatar
Vespa PK 50 XL
Not especially for disc brake models, but I use a U-lock on my PK whenever there is no possibility to lock it up properly to a post or something.
The U-lock goes through the brake pedal lever and it locks up behind the centerstand. So it puts some pressure on the back brake and additionally the stand can not be opened up, both things make it a bit harder to drag along by a possible thief.
Of course this can not prevent lifting the scoot up to a van etc
Here is some pics of my solution:
nothing at all
nothing at all
try to get the fat part thru there and it will lock up your wheel
@macallu avatar
Vespa PK 50 XL
@macallu avatar
Vespa PK 50 XL
Good advice! I will check it out, thanks.
@theoz avatar
Sir Frets-A-Lot
Sir Frets-A-Lot
@theoz avatar
so I've been doing similar thing for a while, and Aaron reminds me one day, what about cable stretch...
Is that a potential problem here with this approach?
Another thing I've done is griplock on the clutch.
nothing at all
nothing at all
i don't buy into the stretch theory
steel wrap cable is a none stretch item
bad install and maintnance is a bigger issue Nerd emoticon
yes,a cable may settle into it's adjusters and ends
that's it in my opinion
@steveinsac avatar
2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
@steveinsac avatar
That's a good idea! That and a gorrila allarm (just ask Buglake) would be good diterents.
@nick_j avatar
PX200E, V100
@nick_j avatar
PX200E, V100
I use a kryptonite chain and padlock - I can't remember the name (I think it was a New York or something) but it's the heaviest duty chain they make for bicycles. Put it around the front shock and chain it to anything I can. The chain was the only manageable one I could find that has a good report against bolt cutters...
Some good ideas here But idealy tatchman approved to bring the insurance down. Im a tight old ba@%ard i know.
[ Time: 0.0113s ][ Queries: 4 (0.0030s) ][ live ][ 343 ][ ThingOne ]
