@maurine7 avatar
GTS 125CC
@maurine7 avatar
GTS 125CC
When I press down on the front brakes they sound like crickets but the rear brakes are silent - is this normal or the sign of a malfunction?
2003 ET4, 1972 Primavera
Normal
@nigelthefish avatar
ET2, PX150
ET2, PX150
Might be the wear indicators on your pads. How many miles on the bike? Do you favor the front brake?
@dillinger-63 avatar
Had 2 2006 GTS 250ie's
Re: Mt front brake sounds like crickets????
Both my 07 and 08 GTS did it from day one, I think they all do, just the nature of the brake pads against vented discs.
@maurine7 avatar
GTS 125CC
@maurine7 avatar
GTS 125CC
I had the bike from new for just under 2 weeks, have done under 400km on the bike. I favour the front brakes more as I was told to use the front brakes when braking in a straight line first and then the rear and I was told to only use the rear brakes first if braking when doing a corner.
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
Mine sounds more like a muted cicada.
So yeah, if it sounds like some type of chirping insect, it's normal.
@benito avatar
@benito avatar
As everyone else has said it is completely normal and nothing to worry about. Both my GT and GTS displayed this behaviour from day one. It is related to the holes in the front disk brake.
@techguy avatar
@techguy avatar
Has anyone heard that if you sand a slight bevel into the leading edge of the brake pads that the noise may be minimized? I think I read this somewhere.
Then again I may be spewing useless fluff... your choice!
That should minimise it - it may not reduce it completely. An easier way is to bevel off the leading edge of the pads themselves. Again, it won't quite them completely.
Me, I don't worry about it, it's normal so that's OK in my book.
@big-7-baz avatar
AUTO. & TRAD.
@big-7-baz avatar
AUTO. & TRAD.
Nothing to worry about, its air in the holes escaping.
It's the equivalent of a rather poorly made 'penny whistle', which is why the bevelling can help (unnecessarily) to reduce it.
Have you all forgotten the wiki already? Crying or Very sad emoticon
FAQ: Why do my front brakes make a whirring / cricket sound?
@maurine7 avatar
GTS 125CC
@maurine7 avatar
GTS 125CC
cool, i've accepted it's quite normal - thanks all Razz emoticon
@marco_luigi avatar
2009 Vespa GTS 250ie
@marco_luigi avatar
Ditto ... the rear brakes are doing the same ... only you can't hear 'em because they're drowned-out by other noise ... no worries, keep riding
@maurine7 avatar
GTS 125CC
@maurine7 avatar
GTS 125CC
ahhh haaa! i now understand - will also peruse wiki
@benito avatar
@benito avatar
No I actually remembered it but was too lazy to post a link to it.
[ Time: 0.0097s ][ Queries: 3 (0.0030s) ][ live ][ 339 ][ ThingOne ]
