@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
It was in my bag with the flywheel hardware, but it doesn't appear to go there.
It's quite thick.
The local scooter shop thinks it might go on before the clutch.
It obviously has a notch for a woodruff key...?
i have a few
i have a few
its a spacer for when you disconect the auto lube. it goes in place of the oil cog behind the clutch.
@rover_eric avatar
@rover_eric avatar
yeah...pretty sure thats a clutch thrust washer....goes between clutch and seal
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
i dug this up because I forgot which side faces the crankshaft?
@rover_eric avatar
@rover_eric avatar
i'm pretty sure it cups OUTWARD
@jamesjohn avatar
@jamesjohn avatar
So flat side to the center of engine and beveled edge towards the clutch? Thanks
@greasy125 avatar
@greasy125 avatar
i'm fairly sure that it goes flat side to the bearing, bevel to the clutch.
best,
-greasy
@jamesjohn avatar
@jamesjohn avatar
Cool. Thanks.
[ Time: 0.0080s ][ Queries: 4 (0.0020s) ][ live ][ 343 ][ ThingOne ]
