Ok, let me preface this with "I'm still a complete and utter noob when it comes to fixing these things". As I've said in other threads, I've never worked on any type of engine before I bought my P200 late last year. Everything I've learned, I've learned from reading.
I was on my way to work this morning, when my ride was running kinda sluggish and jerky.
So I was like "maybe I'm almost out of gas" (i hadn't ridden in a while and couldn't remember the level of gas i had). So, I pull into the nearest gas station, but i have a 3/4 full tank! WTF? So I'm like, fuck it, i might as well fill up. So i pump the gas and try to start it up... not happening.
Then I look down. There was gas, not leaking, but pouring from the bottom of the bike. Luckily, it stopped when I closed the petcock.
Now I've had a gas leaking problem before, so I wasn't freaking out just yet. The problem was that the fuel line screw was loose on the carb. Well... that wasn't the case this time. That's when i started freaking out.
To make a 3 hour story short. My girlfriend luckily wasn't working this morning, so she was able to help me out. She brought me the Haynes manual (which I will now carry with me everywhere), and was able to go to an auto parts store to get me a siphon pump... not to mention the tremendous help she was as my mechanics assistant. She's great.
After much fumbling, and trials and errors I figured out the fuel line was splitting and had disconnected from the tank. It took me 3 hours to diagnose, figure out how the hell to fix it, and to do it. It was in the upper 90's this morning and I had no shade in a horribly clear and sunny day... not to mention I hadn't eaten yet.. ok, now I'm just bitching...
So here's what I learned today:
1. In order to do one thing on these bikes you have to do 5 things before you can do the original thing.
2. Tools get hot in the sun.
3. When your bike starts running funny right when you leave your house, don't say "I'm sure its just fine, it just needs to warm up"... Turn around and take the car or fix it at the comfort of your own home.
4. Don't freak out that you don't know what to do.. Its usually a lot simpler than you believe it to be.
So, needless to say, I didn't make it to work this morning, but the good part is, now it runs a lot better than it has been for the past couple of weeks. Sweet.
