2009 Vespa GTS 250ie
Posts: 108 Location: Melbourne, FL, USA |
I went out for a ride this morning ... about 90 miles in all. On the last leg home, the check engine light came on as I was braking, and then it would go off a few moments later. It did this several times as I approached home. I rode a good portion of the trip at 70+ mph ... not quite WOT, but almost. The same thing happened once before when I had a passenger. I've had passengers before and since that incident. At the time I blew it off as a fluke. But now it happened again without a passenger. Any ideas? Did I stress the engine? Everything seems ok ... temp was medium, oil level good, half tank of gas, etc.
2009 Vespa GTS250ie 'Constance'
Posts: 344 Location: Marietta, Georgia |
All I can offer is that I had the exact same experience at 1400 miles and it has not happened since in the last few hundred miles.
*edit to appear literate ⚠️ Last edited by that L do pig on UTC; edited 3 times
21 75th Anniv. Primavera, 10 GTS Super 300, 64 Allstate, 61 VNB, 61 GL, 61 Lammy LI 125 Mahi Shriner, 57 Lammy LD125
Posts: 1410 Location: Baltimore-Washington-Asbury Park at the Jersey Shore |
Not a problem unless it comes on and stays on even when you restart the scooter. Mine often goes on during very long downhill rides.
that L do pig wrote: All I can offer is that I had the exact same experience at 1400 miles and it has not happened since in the last few hundred miles. Bobovespa wrote: Not a problem unless it comes on and stays on even when you restart the scooter. Mine often goes on during very long downhill rides. Thanks guys. Thumbs up to the both of you! |
Check that the spark plug wire is firmly attached at both ends. The plug cap wire connection is often suspect... not screwed fully home. The cap screws onto the wire. Would account for your symptoms.
Positive
dougl65 wrote: Check that the spark plug wire is firmly attached at both ends. The plug cap wire connection is often suspect... not screwed fully home. The cap screws onto the wire. Would account for your symptoms. That reminds me of something else too: the first week I had my Vespa, the check engine light occasionally flickered on and then eventually it konked-out and wouldn't re-start. My Vespa dealer at American Biker offered to come pick-up my scooter, but first wanted me to check the battery connections. The positive connection screw came loose. It still has a tendency to loosen-up occasionally. Unfortunately, this time that was not the case. So, two more things on the trouble-shooting list: loose spark plug wire AND loose battery connections. Thanks ... thumbs up! |
Posts: 46029 Location: Pleasant Hill, CA |
The following doesn't sound like your scenario - but if the engine check light comes on at high revs then check the regulator output - it may have a fault giving too high a current into the battery which will dry that out PDQ. Worth checking regulator output anyway, even if just to eliminate it.
Positive
Posts: 5707 Location: Santa Cruz California |
Doesnt the controller store codes that can be checked when the check engine light comes on?
Yes - but that'll need a trip to a dealer that has a diagnostic unit, not all do in the US it seems.
jimc wrote: The following doesn't sound like your scenario - but if the engine check light comes on at high revs then check the regulator output - it may have a fault giving too high a current into the battery which will dry that out PDQ. Worth checking regulator output anyway, even if just to eliminate it. That might not be my case either as later that evening I brought her out on the expressway and went WOT for 10 minutes ... no light. It seems to happen only under high stress over time - a couple of hours. Then again, it only happened twice thus far. I'll keep an eye on it and record it here if it happens again. Miguel wrote: Doesnt the controller store codes that can be checked when the check engine light comes on? |
GTS250 - GT200 - XJR1300
Posts: 1424 Location: SW London, UK |
Beer Fairy
GTS-"Cannonball Bettie" Member Iron Butt Association
Posts: 851 Location: Seacoast New Hampshire USA |
Beer Fairy
jimc wrote: The following doesn't sound like your scenario - but if the engine check light comes on at high revs then check the regulator output - it may have a fault giving too high a current into the battery which will dry that out PDQ. Worth checking regulator output anyway, even if just to eliminate it. The engine light was coming on an awful lot lately. I ignored it because "it will just go away" but, next thing I knew, I couldn't start the bike. I couldn't believe it was because of the battery since I had bought it less than 6 months ago and it was a good one (i.e., Yuasa brand). However, when I took it out and showed it to the mechanic, they realized immediately that there was no liquid inside and the battery had been fried. Now the mechanic is asking for a $600 repair to replace the regulator. I'm seeing regulators for sale for $100 -- not sure if the quote is too much... |
lights
I had this problem, it was a dead sensor in the engine. It was replaced during it's service. The part was only £9.00. Gass silver machine gts 250
citanul wrote: jimc wrote: The following doesn't sound like your scenario - but if the engine check light comes on at high revs then check the regulator output - it may have a fault giving too high a current into the battery which will dry that out PDQ. Worth checking regulator output anyway, even if just to eliminate it. Quote: The engine light was coming on an awful lot lately. I ignored it because "it will just go away" but, next thing I knew, I couldn't start the bike. I couldn't believe it was because of the battery since I had bought it less than 6 months ago and it was a good one (i.e., Yuasa brand). However, when I took it out and showed it to the mechanic, they realized immediately that there was no liquid inside and the battery had been fried. Now the mechanic is asking for a $600 repair to replace the regulator. I'm seeing regulators for sale for $100 -- not sure if the quote is too much... |
I asked the mechanic if they couldn't give me a better quote -- they say because it's a GTS 250, they'd need to take a lot of stuff out. As for the price of the regulator itself, they say it's because they work with the genuine stuff.
I'll give other mechanics a call and see if they provide any lower quotes. |
It's pretty easy to do it yourself - just the horncast, glovebox and floorboard to remove to gain access.
