'08 Piaggio Fly 150
'08 Piaggio Fly 150
Thanks to a recent post about tire pressures, I have been paying attention (read: obsessed) with this since having Conti Zippy's put on a few weeks ago. I use a tire pump that plugs into the cigarette lighter of my car for power, but I'm wondering what you all use. I'd rather have something I can plug into an AC outlet for power. Any suggestions?
As always, thanks!
-- Laura
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
Re: Tire Air Pump
As always, thanks!
-- Laura
Laura,
I use a Powerlett plug to an SAE it allows me to add air while I am on the side of the road if needed. For very little money this is a nice mod that will also allow you to use a battery tender in the garage or heated gear during the cold months. More reading in this thread. Good luck and stay safe. Monitoring your tires is a great habit to get into.
@xmanhoe avatar
@xmanhoe avatar
NICE MOD
Sweet is that a volt meter? also what does your little decal say? cheers Bill
@fluffy avatar
Beverly 350 "Mavis"
@fluffy avatar
Beverly 350 "Mavis"
I check my tires weekly at a local servo. It has one of those digital gauges that go beep, but nonetheless I keep a pencil type pressure gauge in my glovebox to double check (service stations tend to overinflate, mostly)
In an emergency i have a bicycle pump which does the trick, while also providing a great upper-body workout!
@2011super avatar
@2011super avatar
Re: NICE MOD
Yes that is a Datel Voltmeter. The decal reads No I do not want a Harley and one the other side there is one that says no this is not a damn moped.
Cheers Trent
@2011super avatar
@2011super avatar
I use something called Smart tire on my FJR motorcycle and have really thought about adding it to the scooter too. LINK
Model TPMS-MC specification:
Alarms: 1st stage flashing light, 2nd stage continuous light.
Manually check pressure, pressure deviation, and temperature.
Kit includes: Display, 2 tire sensors & steel bands, wheel labels, User Manual.
Alarms at: 15% under and 25% under pressure, and over 80 C.
23 x 42 mm high display. Free self assembly template for download.
Pressures indicated in psi or bar, temperatures °C or °F (please select).
If you use an electric pump - make sure it is a 12V one that can be powered from the scooter - NOT from the mains. There may be times that you need a top-up - or a fellow PTW rider does - with no mains electricity within miles.
A few CO2 cartridges with adapters won't go amiss either.
@xmanhoe avatar
@xmanhoe avatar
nice
cheers here is my plate
@2011super avatar
@2011super avatar
To add to what JimC said here is a great link to some tire pumps. I bought 2 of the Slime units but wish I would have read this review and bought the Airman. Link to article.
@menhir avatar
@menhir avatar
A bicycle pump. One of those little ones.
EDIT: Oops..my bad. I didn't see that last line about wanting something that runs on AC power. I was thinking of on the road.
In any case, I don't bother with AC power pumps. I'd still rather have something that can inflate a tire wherever I am. I have a 12V electric pump in my car for that. I've never taken it with me on the scooter though...yet.
As an aside, you can't always trust the gauges that come with the pumps. I always double-check the inflation with a tire gauge.
⚠️ Last edited by Menhir on UTC; edited 1 time
@masala avatar
@masala avatar
946
I picked up something along the lines of this a few months ago and haven't looked back! Tire pressures on *every*thing are set - cars, Vespa, bikes, hell even the neighbors if they want! Laughing emoticon
@zwerski avatar
@zwerski avatar
I use a bicycle pump.
@glasseye avatar
@glasseye avatar
I like these...small, light....kinda cheap.
Mine have been quite durable.
http://www.twistedthrottle.com/trade/productview/4573/
R
8)
@chetwynder avatar
Baart-less
@chetwynder avatar
Baart-less
$10.00 (CDN) The gauge isn't worth spit, but for adding a few pounds every now and then the pump works great. For what it's worth I tried several different gauges, digital, round analog type, pencil type all different price ranges too. In my testing (which was far from scientific) I was happiest with a $6.99 pencil type gauge, it gave the most consistent results. I found the round analog type that hold the reading until released broke after very few uses and the digital gauges i tried gave a different reading almost every time. The good old standby pencil type just work - for me anyway.
Dave
@michael_moore avatar
GTS(me)/GTV(wife)
GTS(me)/GTV(wife)
I have one of those electric jobbies, but in truth all I ever use is this one:
I think it cost me $25 at REI on sale.
@tb avatar
@tb avatar
I tried the $10.00 foot pump mention in earlier post from Checkers (other outlets carry same...made in China). Returned it twice due to leak in tube got my money back and am using my trusty bicycle pump that has a dual schrader and presta connection...it's simple and easy to connect and inflate...couple of pumps and done... reliable for at home / before a ride inflate...check it once a week.
On the road, I have a tire repair kit...which includes CO2 cartridges.
@2011super avatar
@2011super avatar
I spent only $10 on my Slime air compressor. Cheap and small.
[ Time: 0.0141s ][ Queries: 4 (0.0074s) ][ live ][ 343 ][ ThingOne ]
