@retro_s avatar
vespa s 125
@retro_s avatar
vespa s 125
hi i have this nut that's loose , its on top of the clutch . what is it? is it suppose to be loose?
@louispain avatar
Cosa and P200E
@louispain avatar
Cosa and P200E
It´s the engine breather. Mushroom shaped thing on top of the clutch housing.
Take it out, make sure it´s clear. Refit and tighten.
@retro_s avatar
vespa s 125
@retro_s avatar
vespa s 125
how does it come out, i tried to screw/unscrew , nothing happened
@ruckus150cc avatar
1980 p125
@ruckus150cc avatar
1980 p125
The very bottom should have a hex head, turn that. The top is loose and will turn with no avail. Good luck.
Jeremy
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
if you have a side stand on you can leave it on it and watch the oil spit on tick over ...... nice black engine Razz emoticon
@jimh avatar
MV Saint
Haud yer wheesh't if ye cannae be nice
MV Saint
@jimh avatar
Yes mate, Like Louispain stated it's your engine breather.
You will need a 14mm to loosen it. It's best to clean it with petrol or carb cleaner.
Here is a wee picture up close.
Cheers
This is a two way breather
[ Time: 0.0139s ][ Queries: 4 (0.0073s) ][ live ][ 343 ][ ThingOne ]
