@big_foot avatar
Scooterless at the moment
@big_foot avatar
I've been using fully synthetic AMSOIL 2-Cycle oil,
Is this okay to use or should I be using semi synthetic oil?
Can I even switch to semi synthetic oil from fully synthetic?
The reason why I'm asking is because I'm finding that the P200E is running sluggish and will stall.
Although it might be my air filter being clogged.
@aviator47 avatar
@aviator47 avatar
Re: 2 stroke oil type?
Then by all means clean the air filter. Then check the spark plug. As far as switching oil, I don't think fully synthetic is known to be a problem in Vespa engines.
Al
@pawsher avatar
@pawsher avatar
Mine was doing the same, felt as tho they're was no petrol getting thro, or it was flooding. Rmoved the air filter and cleaned ot the 2 jets, bearing in mind the large jet is in 3 parts.
Popped it all back together and it now runs superb.
I have a Polini 152 kit on my T5 and use fully synthetic 'Rock Oil'
@halijaro avatar
@halijaro avatar
I wouldn't use anything but fully synthetic 2 stroke oil. Many people use semi on older P's but I doubt that's where your problem is.
[ Time: 0.0107s ][ Queries: 3 (0.0042s) ][ live ][ 343 ][ ThingOne ]
