I replaced the thermostat and upon testing the system, let it idle and run to normal temp (just below half on the gauge) and cycle several times through the thermostat opening and closing, checking the coolant reservoir for warmth, proving the system was operating as intended. All was fine.
Upon riding the scoot in cool temps (55-60 degrees) the scoot's gauge sits well below normal, mostly at or below 1/4. That is running at all speeds, highway, freeway, city, etc. I brought the issue up to a couple people at a group meetup recently, and the suggested that I need to bleed the coolant system, which I never did when I installed the thermostat.
What I did do was to run the scoot to temp and let idle for 15 minutes with the reservoir cap off, but did not keep my eye on checking for air bubbles.
in the system.
Then today, I came across this thread about coolant replacement:
https://modernvespa.com/forum/topic29213?highlight=coolant
Since there is no bleeder nipple as there is on the GTS, how can I be sure I have bled out the air in the coolant system of my GT and how can I get my scoot to run at the proper temperature like it's supposed to?
⚠️ Last edited by Zwerski on UTC; edited 4 times
