A friend brought me his bone-stock '74 US-spec Primavera. It had never had a complete cable change on it...so he brought me one of those "universal cable sets" for a smallie. This one was Mercur brand. I used the whole cable-swapout method i detailed in a different thread, and for the most part it went ok. It did remind me of some details i want to share, though.
1) You may or may not know this, but stock, from the factory, they put a metal crimp on the two gear selector cables, tying them together. The two are crimped together up near the headset end. Why they did this, i have no fucking clue... because getting them out means pulling them carefully up through the headset area. If you try to get them out through the bottom you'll have a miserable time. This is about the 10th bike i've done with this stupid crimp thing. If you are using the double-length cable trick, this will ruin your day. Just an FYI that if your outers have a really waffle-pattern look about them, they are probably the original outers, and so your gear selector outers might be tied together.
2) I cannot stress this enough ... MAKE SURE YOUR OUTER CABLES ARE CUT PROPERLY TO LENGTH. These universal kits they are selling are a good 7-8" longer than they need to be, assuming that you're going to cut them to length. I basically ran all my outers ...hooked them up before cutting them to length, and it was terrible. The gear selectors barely shifted it into gear...and not cleanly. The clutch was very hard to pull,etc. Basically all that excess outer was causing a lot of undo friction, i assume.
When i undid all the cables, i took a dremel wheel to the outers ( after holding them up to the little fine-tuner things to measure them ), and hacked off the 7" or so of outer material ... being careful not to nick the inner... and then reattached. Man, it's like night and day. They suddenly felt slick and required no effort to shift or squeeze the clutch. It was a borderline unrideable bike beforehand, and felt brand new afterward. So... please please please if you run new cables make sure that you dremel off the excess outer.
3) I find that the cables you buy that have a plastic ( teflon, maybe? ) sheath inside of the outer, between the inner and the outer, are best. Check to make sure the cable sets you order are teflon lined. Those are quite nice and you don't have to worry about oiling them as much.
-Eric.
⚠️ Last edited by Rover Eric on UTC; edited 1 time
